Hello!
This thread is quite big and the tutorial from 2013.
I was running XBMC 12.? and today I installed the latest Kodibunto.
My System is a Acer Revo RL70 with an AMD E-450 + Radeon 6320
I was running the fglrx Drivers to get files with DTS-Audio run smooth.
I have read that nowadays vdpau is the new way to get DTS-Audio files running and i noticed that my installation of Kodi allready comes with vdpau drivers (as seen in my Settings), so i made the settings in Kodi that were suggested in this tutorial... I guess the other part is irrelevant?
I also set the Audio on Passthrough since my revceiver can handle DTS-HD, etc..
However Some DTS Movies still stutter on some scenes and i dont know if this is a issue with vdpau or an issue with my network (sometimes it says buffering), its just strange i had no issues with XBMC 12
Provide the logfiles the first post wants you to provide. If you did not follow this hoto at all -> choose another thread.
(2015-05-30, 08:38)fritsch Wrote: [ -> ]u= "nothing" <- are you kidding me? If u = kodi user, then that's perfectly clear ...
why is that perfectly clear?
since the kodi user still has rw rights on the file through group rights it should still be able to play the file.
this strange permissions resulted from unraring a rar file.
fritsch@t440s:~$ touch heinzasd.txt
fritsch@t440s:~$ chmod 064 heinzasd.txt
fritsch@t440s:~$ cat heinzasd.txt
fritsch@t440s:~$ LANG=US cat heinzasd.txt
cat: heinzasd.txt: Permission denied
so?
After deciding to update to Kodi, requiring me to update to Trusty first and as a result nuking my install I decided to start over. Followed the howto to a tee and have most of the system working as before but no sound cards are found according to aplay -l. Where to start? Please advise, thanks.
Post the logs from first page and afterwards it will be solved easily ...
mmh, nothing in dmesg ...
sudo aplay -l | pastebinit
lsmod |grep -i snd | pastebinit
Both are empty, so I just output here
kodi@kodi:~$ sudo aplay -l | pastebinit
aplay: device_list:268: no soundcards found...
You are trying to send an empty document, closing.
kodi@kodi:~$ lsmod |grep -i snd | pastebinit
Check if it's disable in the bios (unlikely for hdmi audio). Try OpenELEC from usb stick and see.
BIOS checked: OK. I saw Pulse was not installed in the logs but as per doc I shouldnt need to. What do I look for when trying OpenELEC?
Tried this as well:
kodi@kodi:~$ sudo lshw -C sound
*-multimedia:0 UNCLAIMED
description: Audio device
product: Wrestler HDMI Audio
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 1.1
bus info: pci@0000:00:01.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: latency=0
resources: memory:feb44000-feb47fff
*-multimedia:1 UNCLAIMED
product: SBx00 Azalia (Intel HDA)
physical id: 14.2
bus info: pci@0000:00:14.2
version: 40
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: latency=32
resources: memory:feb40000-feb43fff
Audio works in OpenElec out of the box. Lists the device as HD-Audio Generic. Please advise, thanks.
Good, then upgrade the kernel, please to something newer. You can use Ubuntu mainline to accomplish that.
Perhaps easier:
sudo apt-get install linux-image-generic-lts-vivid linux-headers-generic-lts-vivid
via the trusty-updates repo
Thanks a lot: that solved it!
