(2013-10-19, 08:02)beschmid Wrote: [ -> ]@fritsch: When I enable Live TV my system freezes. Is there a log or any info I can provide you to troubleshoot this?
xbmc.log with debugging turned on. Btw. LiveTV is my primary scenario and it obviously works for me. Check the relevant output concerning glinterop and vdpauinfo.
I updated the howto to now use 3.12-rc5 and some patches made by Alex Deucher, which fix the audio clock and enable audio without the xrandr hack, when adding radeon.audio=1 to the command line.
I kept the patch someone said would be needed for radeon si.
@ ln17 -- did you copy and paste....? 'cause i see a syntax error.
(2013-10-19, 04:58)beschmid Wrote: [ -> ]@locomot1f: I just did. Do you know of any other support forums or bug reporting sites we can add to on this? I am not sleeping until I get this working
i would have to refer to @
fritsch, or some of the other more senior members on this post.
hard to believe that there are just three of us out there with this hardware.
The first row is typing error, otherwise I do copy and paste everything based on the instruction.
lajosnagy17@lajosnagy17-ProLiant-MicroServer:~/kernel$ ls
linux-headers-3.12.0-rc5_2.2_amd64.deb
lajosnagy17@lajosnagy17-ProLiant-MicroServer:~/kernel$ sudo dpkg -i *deb
[sudo] password for lajosnagy17:
(Reading database ... 272339 files and directories currently installed.)
Preparing to replace linux-headers-3.12.0-rc5 2.2 (using linux-headers-3.12.0-rc5_2.2_amd64.deb) ...
Unpacking replacement linux-headers-3.12.0-rc5 ...
Setting up linux-headers-3.12.0-rc5 (2.2) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 3.12.0-rc5 /boot/vmlinuz-3.12.0-rc5
Error! Your kernel headers for kernel 3.12.0-rc5 cannot be found.
Please install the linux-headers-3.12.0-rc5 package,
or use the --kernelsourcedir option to tell DKMS where it's located
you seem to be missing the linux image, linux-image-3.12.0-rc5_2.2_amd64.deb
fritsch that new kernel put everything in slow mo. Xubuntu desktop and pulse. I know not supported. Just FYI. I will dig deeper. Even YouTube music vids are in slow no. 7to10 fps.
Thank you. It was my fault.
@gfisher:
I cannot reproduce - as I am running it since three days without issues before I posted the kernel.
If you boot the older kernel, all is fine again? It seems you miss some acceleration. Logfiles welcome.
using the 3.12.0-rc5 kernel, working fine on my E350.
Okay. For all with kernel problems, please file bugs on freedesktop. The AMD oss devs are keen to fix such issues, they are really helpful.
I've seen couple of people with gentoo in this thread. Can someone share their ebuilds/overlays?
Fritsch thx. I removed pulse and it works on the new kernel. But no sound. Xubuntu is sketchy without pavucontrol. I probably will have to reinstall to clean. The bigger issue is h.264 59.94p still skips too much, I notice it on playback OSD W moves 55-60. Both kernels. I suspect it is a model line or that 1080p is only getting 50fps on my test. Xvba and gt610 were good in this regard.
Edit - once I get sound working will post logs
add radeon.audio=1 or use the xrandr to enable it.
You cannot decode more than qvdpautest is able to decode, e.g. 59.94 won't work.
