thanks for your logs, but sadly not a debug log. I cannot see anything :-(
Between 21:35 and 21:40 is the only record 8 x "UPower: Received an unknown signal DeviceChanged" (it's power management related?). At the time was about 3-4 sound dropouts.
'21:35:23 T:140459120785152 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:10349.066000, should be:20666.666667, error:10317.600667' it's not the problem?
Those are too unfrequent :-)
I expected a pattern every some seconds. Try setting Sync Method to Audio Clock.
the old bug was: "Get read without package available" which I cannot find in there.
(2013-10-26, 12:02)fritsch Wrote: [ -> ]Keep the A4 and follow the howto - done. No need to buy anything new.
I already did that 3 times. Installing the latest driver and kernel just provides me with a black screen with GPU lockup messages on it.
I'll try it one last time. Maybe something has been fixed in the meantime but I doubt it.
Snippo Can or do you care to run xubuntu64 desktop. Pm me if you have any ?s. I have the a4 3400 running like a champ. It is a lot of GPU for simple 1080p HD playback. What is your hardware? This should work for you.
I tried both Lubuntu64 and the mini iso. My own system is an A4-3400 + Gigabyte A75M-UD2H. I'm giving it a try on a different system now with an A4-3400 + ASRock A75M-ITX to see if that will work.
(2013-10-27, 11:36)deadite66 Wrote: [ -> ]did you hear the audio clip i posted yesterday?
recorded from TV headphone out so not brilliant quality.
weird audio
glitch starts at 5 seconds and ends at 11 seconds.
I was curious, and tried your sample on my Windows7 laptop, by playing with vlc.
I got exactly the same result, weird noise between sec 5 and 11.
I start thinking that the problem is how the sample was encoded.
Hi, here is a new rc7+ kernel with the lipsync patches integrated again:
wget https://dl.dropboxusercontent.com/u/55728161/linux-headers-3.12.0-rc7%2B_0.1_amd64.deb https://dl.dropboxusercontent.com/u/55728161/linux-image-3.12.0-rc7%2B_0.1_amd64.deb
sudo dpkg -i *0.7*deb
I am still searching frequent, repeated audio drops with especially passthrough formats. On older kernels we lost 10ms every 6 seconds, that has improved (somehow) a lot. So please, if you test those kernels. Let them run in passthrough + debugging and capture your logfiles.
Currently I am interested in correctly periodically drops at an interval < 40 seconds. So, if you have some drops every 5 minutes, those are not yet relevant.
Thanks much for testing.
(2013-10-28, 10:45)Claudio.Sjo Wrote: [ -> ] (2013-10-27, 11:36)deadite66 Wrote: [ -> ]did you hear the audio clip i posted yesterday?
weird audio
That sample had the noise recorded :-) - so quite clear you hear it.
I tried today this howto. VC1 sample from @
laric (vc1_1080p_ap_l3_18mbps_ac3_hddvd.mkv) don't play. I just get sound but no picture. I will post logs tomorrow.
I think the hardware (HD4290 (UVD2) with AMD Sempron 140) is not enough powerfull for this file. I will try with a AMD Athlon II X4 610e.
