I kept getting errors about the HAWAII drivers.
i know you said that this forum will become obsolete when 3.13 is released.
so, should I purge the repository ppa:wsnipex/mesa, and just use the mainline?
I've also had another successful run with 3.13-rc2 with no issues. I am wondering if the people having problems have newer GPUs?
Quote: [<ffffffffa01b7ecb>] dce6_afmt_write_speaker_allocation+0xdb/0x140 [radeon]
Head over to the usual location :-)
(2013-12-03, 17:01)locomot1f Wrote: [ -> ]xbmc@xbmc:~$ dmesg | pastebinit
http://paste.ubuntu.com/6514897/
xbmc@xbmc:~$ cat ~/.xbmc/temp/xbmc.log | pastebinit
http://paste.ubuntu.com/6514899/
xbmc@xbmc:~$ cat /var/log/Xorg.0.log | pastebinit
http://paste.ubuntu.com/6514901/
xbmc@xbmc:~$ DISPLAY=:0 vdpauinfo | pastebinit
[1]+ Stopped DISPLAY=:0 vdpauinfo | pastebinit
xbmc@xbmc:~$ dpkg -l | grep mesa | pastebinit
http://paste.ubuntu.com/6514909/
as you can see, when I tried to run the DISPLAY=:0 vdpauinfo, it just hangs, and I had to cancel it.
Your mesa looks funky... did you follow the guide? Here is mine:
ii libegl1-mesa:amd64 10.0~git201311181342.37827~ubuntu13.10.1 amd64 free implementation of the EGL API -- runtime
ii libegl1-mesa-drivers:amd64 10.0~git201311181342.37827~ubuntu13.10.1 amd64 free implementation of the EGL API -- hardware drivers
ii libg3dvl-mesa 10.0~git201311181342.37827~ubuntu13.10.1 amd64 xvmc and vdpau Gallium3D video acceleration drivers
ii libgl1-mesa-dri:amd64 10.0~git201311181342.37827~ubuntu13.10.1 amd64 free implementation of the OpenGL API -- DRI modules
ii libgl1-mesa-glx:amd64 10.0~git201311181342.37827~ubuntu13.10.1 amd64 free implementation of the OpenGL API -- GLX runtime
ii libglapi-mesa:amd64 10.0~git201311181342.37827~ubuntu13.10.1 amd64 free implementation of the GL API -- shared library
ii libglu1-mesa:amd64 9.0.0-1 amd64 Mesa OpenGL utility library (GLU)
ii libopenvg1-mesa:amd64 10.0~git201311181342.37827~ubuntu13.10.1 amd64 free implementation of the OpenVG API -- runtime
ii mesa-utils 8.1.0-2 amd64 Miscellaneous Mesa GL utilities
Despite this as @
pyrodex pointed out, you are missing the correct mesa packages.
i did...
sorry i was trying stuff, and I purged ppa:wsnipex/mesa
one sec, and I'll get updated logs...
The problem is the kernel error, this happens when the driver tries to acquire the speaker mask. This was patched out during 3.12, as it caused those issues. Big disadvantage: Speaker ELD acquiering stopped working for everybody, therefore they put it in again.
File that bug at freedesktop.org please. This needs upstream care.
Use your creativity :-) Don't be shy.
It's quite easy:
sudo apt-get install kernel-package fakeroot build-essential libncurses5-dev
git clone https://github.com/fritsch/linux.git
git checkout master
cd linux
cp /boot/config-3.13.0-031300rc2-generic .config
fakeroot make-kpkg --initrd -j6 --revision=0.1 kernel_image kernel_headers
It requires that a 3.13-rc2 kernel was already installed, cause we use that .config.
This will produce two .deb files, which you only have to install via: sudo dpkg -i firstfile.deb secondfile.deb
That master branch includes your segfault patch and the patch the others might need for mpeg-2 (PLL something)
It might need ages on e.g. E350, but you can easily build on other machines and copy over the .debs
don't forget to add the patch before building
untested:
steps from above...
wget
https://bugs.freedesktop.org/attachment.cgi?id=90196 -O drm-fix.patch
git apply drm-fix.patch
I have them in my tree, therefore I ommited that. But will upload two packages shortly.
I compile my kernels with Ubuntu in vmware player on my desktop, saves having unnecessary dev packages and a faster compile.
