Full Version: Cannot access settings side menu in xbmc 13 nigthly
I am trying to change the settings level to expert or advanced, as i would like the "Clean Library" option back.
According to threads on the forum, i am supposed to be able to change the settings level in the confluence skin, by accessing a side menu while in the settings menu.
But i cannot seem to get to this side menu, i,e left clicking does not bring up a menu.
Is there a config file i can change settings level in instead? i.e so i can get access to the clean library feature?
Many thanks for any replies.
EDIT : I am using XBMC 13.0-ALPHA4 Git.f828567 (Compiled: May 28 2013)
BR
Patric
We are at alpha 8 currently.
Thanks for the help.
However, i added this ppa hoping to get alpha8 https://launchpad.net/~team-xbmc/+archive/unstable
But there seems to only be an alpha3 build available for Oneiric (which i am using)
Do you know of another ppa that has alpha8 for Oneiric?
BR
Patric
Does not look like those have been updated since may either. Confused
Ah! Oneiric.
Not supported anymore.
launchpad does not allow us to build for deprecated series such as oneiric. You'll have to upgrade.
