Hi, I just had to reflash my DM800 with a new version of openpli and due to a copyright claim its using open-webinf but loading the epg and zapping seems to be super slow compared to the old dmm webinf
Hello Mr. jdembski,
is it possible to make a zip file for us noobs, so we can install it easily,
It is not that i want to take the easy road, but i looked at the documentation on how to compile,
and decided it was way easier to climb the mount everest then compile ann add-on.
Thanks in advance, Dj Kolk.
(2013-11-03, 19:17)jdembski Wrote: [ -> ]For EPG loading times you could test some improvements from this post:
http://forum.xbmc.org/showthread.php?tid...pid1510707
Obviously, you would need to compile the add-on on your own...but any feedback is appreciated...
Is there a pre-compiled version available? I cannot connect to my dreambox 800 hd at all. XBMC gives me error message in the right bottom corner.
