I am creating a screensaver that will view show what my CCTV cameras i have started on the code from
https://github.com/dersphere/script.screensaver.test and only changed the background to my URL link that works fine with getting the footage that is currently showing but i need it to refresh every half a second.
How would i put that in the script and where would i put it?
Thank you
can you show the code you used to make the webpage the background.. im trying to do something similar. thanks.
Hi, el_cabong
I stop this project ages ago, as i could not find away to stop xbmc from caching the original pictures and looping through the cache instead of updating to new pictures...
I am using a program called ispy that would create a jpg of the current camera and then update the website every X seconds...
If i remember correctly i changed the file "resources/skins/default/720p/script-Python Screensaver TEST-main.xml" so it read
<window>
<controls>
<control type="image">
<description>Black Background</description>
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
<height>720</height>
<texture>{MY URL}</texture>
</control>............
I ended up using my xbmc setup as a server for the cctv so any recordings and pictures save to the xbmc set up, i then set up just a normal slideshow screensaver and choose the image directory where i store my cctv images...
