Full Version: Intel NUC - Haswell (4th Generation CPU)
I did try it with windows 7 and it works very well. The CIR is really well done, very sensitive and was next to a bright window when I tried it. Looking forward to having it work with a linux os...I am sure it will eventually.
Ernie
(2013-11-09, 19:17)aesalazar Wrote: [ -> ]I did try it with windows 7 and it works very well. The CIR is really well done, very sensitive and was next to a bright window when I tried it. Looking forward to having it work with a linux os...I am sure it will eventually.
Ernie
Thanks for trying it, at least it works well Big Grin. Would rather have a small issue to overcome in linux and really good built in CIR than the other way around Smile
I have a question on the ram for this nuc. It has 2 SODIMM slots, Is it possible to install 1 8 gb card in one slot and it work correctly. I would want to do this in order to increase it to 16gb in the future without much expense.
Pretty sure you can, you just wont get the dual-channel increase. You probably wouldnt notice it though...
Ernie
Doesn't work in XBMCbuntu either, probably the same port not valid thing. I think it's a driver issue
(2013-11-09, 19:38)aesalazar Wrote: [ -> ]Pretty sure you can, you just wont get the dual-channel increase. You probably wouldnt notice it though...
Ernie
What dual gb would you recommend for mainly xbmc streaming and down loading / playback of movies to and from hdd. Some internet surfing.
(2013-11-09, 14:15)aesalazar Wrote: [ -> ]@lmyllari: Good stuff. But it didnt work for me unfortunately. I was able to confirm that I was getting the same message in my boot log. The tee and modprobe seem to go without error but I still do not see lirc0 show up in dev. irw doesnt see anything and mode2 error out.
Are you using OE? I ask because you mention sudo in your commands but should not need that.
I have OE dual boot planned but I'm using 64bit Ubuntu 13.10 for now.
Try unloading the driver first with
modprobe -r nuvoton-cir
I'll verify this with OE once I get my dual boot sorted out. Then I need to figure out where to get a suitable remote..
Sorry to go off topic, but can I get a 'it's not fair, I wanna play' from everyone else in the UK where we don't even have a hint of proper delivery date yet?
Ta.
Carry on.
(2013-11-09, 19:32)mushoss Wrote: [ -> ]It has 2 SODIMM slots, Is it possible to install 1 8 gb card in one slot and it work correctly.
I've got a single 2GB SODIMM in mine, and it works great.
(2013-11-09, 06:31)lmyllari Wrote: [ -> ]Try to enable the device:
$ echo "auto" | sudo tee /sys/bus/acpi/devices/NTN0530\:00/physical_node/resources
$ cat /sys/bus/acpi/devices/NTN0530\:00/physical_node/resources
And load the driver:
$ sudo modprobe nuvoton-cir debug=1
Testing with
$ sudo mode2 -d /dev/lirc0
reports events when I point a random remote at it and push buttons. Smile
I booted Ubuntu 13.10 off a USB drive and pulled up a terminal, and while I'm not great with linux, I can type in commands, and I could do each step until the "mode2" line. At that point I did 'ls /dev' and noticed there was no "lirc". Then I tried "mode2", and was told that command didn't exist, but I could apt-get lirc to add it. When I did this: "sudo apt-get install lirc", I got:"Package lirc is not available, but is referred to by another package."
I'm out for the rest of the day, but I'm happy to do anything I can to help the devs with this one.
(2013-11-09, 20:12)lmyllari Wrote: [ -> ]I'll verify this with OE once I get my dual boot sorted out. Then I need to figure out where to get a suitable remote..
Here are the steps in OE:
i5-nuc:~ # modprobe -r nuvoton_cir
i5-nuc:~ # echo "auto" > /sys/bus/acpi/devices/NTN0530\:00/physical_node/resources
i5-nuc:~ # modprobe nuvoton-cir
i5-nuc:~ # dmesg | tail -20
[    5.761398] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[    5.761442] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  185.961113] pnp 00:08: [io  0x0240-0x024f]
[  185.961150] pnp 00:08: [irq 3]
[  185.961155] pnp 00:08: [io  0x0250-0x025f]
[  190.799643] Registered IR keymap rc-rc6-mce
[  190.799918] input: Nuvoton w836x7hg Infrared Remote Transceiver as /devices/pnp0/00:08/rc/rc0/input10
[  190.800584] rc0: Nuvoton w836x7hg Infrared Remote Transceiver as /devices/pnp0/00:08/rc/rc0
[  190.804930] IR NEC protocol handler initialized
[  190.805066] IR RC5(x) protocol handler initialized
[  190.806204] IR RC6 protocol handler initialized
[  190.807553] IR JVC protocol handler initialized
[  190.808110] IR Sony protocol handler initialized
[  190.810806] IR SANYO protocol handler initialized
[  190.813132] nuvoton_cir: driver has been successfully loaded
[  190.816138] input: MCE IR Keyboard/Mouse (nuvoton-cir) as /devices/virtual/input/input11
[  190.816359] IR MCE Keyboard/mouse protocol handler initialized
[  190.816656] lirc_dev: IR Remote Control driver registered, major 248
[  190.817131] rc rc0: lirc_dev: driver ir-lirc-codec (nuvoton-cir) registered at minor = 0
[  190.817133] IR LIRC bridge handler initialized
I'm not sure how things should be configured after this - it looks like there is an input device and a lirc device that could be used. Now I just need to get an MCE remote..
Also, I wonder what the right way is to fix this. Is the ACPI data incorrect, or is the driver supposed to enable the device before validating the resources?
(2013-11-09, 20:16)ChopD Wrote: [ -> ]it's not fair, I wanna play
Nod
(2013-11-09, 16:34)bakito Wrote: [ -> ]I want to buy a nuc for xbmc and excuse me if this has already been ask, I 'm new to mini pc, I was wondering if this one " Nucleus Mini
Mini-PC, Processeur Intel Celeron 847, Intel HD Graphics, 4096 Mo (4 Go)" is enough to play 1080 movies ? or do I have to buy the I3 version?
did someone tested it? is it ok?
thanks for your advices
cheers
I have a Celeron with Intel HD Graphics in my micro HDPC and it plays all my movies in 1080p perfectly with great audio through my AVR.
(2013-11-09, 20:52)lmyllari Wrote: [ -> ]
Using these commands, the IRW now picks up the remote and it works fine! The only problem is that I guess this will need to be run every single boot? I restarted my NUC and it went back to not working.
(2013-11-09, 19:51)mushoss Wrote: [ -> ]
Ernie
This is what I got. Anything that os 1.35v should work though:
http://www.rakuten.com/pr/product.aspx?sku=223775934
The kernel has a db of devices (vid:pid) that each driver maps to. Sometimes new devices come along that can still use the driver but their vid:pid aren't in the database. Thr kernel won't automatically load the driver but it can still be loaded manually. This may be possible yo fix in modeprobe.conf.
