(2014-04-08, 07:34)fritsch Wrote: [ -> ] (2014-04-08, 00:54)WilliamG Wrote: [ -> ]Does the 4400 pass 24p correctly? I mean REALLY correctly? I would like perfect 23.976hz playback if I go down this road... Thanks.
Also, how quiet is the NUC, if you're sensitive to noise and sit just a couple feet from it? It will just be used for watching 1080p/720p/24 material.
Yes 100%. Remember to "pass" that mode correctly, all your Output devices need to be able to do it (AMP, TV, ...) - you won't believe it, but there are TVs out there that especially with that "200 hz" features calc in between images that introduce hard stutter - so handle the TV "marketing settings" with care.
Thank you. Just picked up the i3 tonight for $259.99. Have RAM arriving tomorrow since my 1.5v chips won't work. Boo!
Thanks again.
Question: What settings need to be enabled in XBMC for "pure" 24p from the Haswell NUC?
(2014-04-08, 12:00)WilliamG Wrote: [ -> ]Question: What settings need to be enabled in XBMC for "pure" 24p from the Haswell NUC?
With openelec I only set Adjust display refresh rate to match video
Of course you have to own an av receiver or a tv that can run with 24p
With frodo I had few stuttering. With Gotham all is perfect.
Could anyone tell me where to find the "Update" folder to add a .tar file to install a new nightly build?
Also, I did my first install using a nightly build, and now that beta 4 is out, how would I install it without doing a clean install?
Thanks as always
(2014-04-08, 14:21)frarev Wrote: [ -> ] (2014-04-08, 12:00)WilliamG Wrote: [ -> ]Question: What settings need to be enabled in XBMC for "pure" 24p from the Haswell NUC?
Thank you. I hope it works. Just waiting for RAM to show up today.
@herbieUK:
I think that you are on the wrong thread here. This is NUC Haswell thread.
I belive that you have even missed forum here.
I'm using OpenElec on my i5 NUC
(2014-04-08, 18:15)Crssi Wrote: [ -> ]@herbieUK:
Exactly, so go to OpenElec forum.
The update folder is /storage/.update. note the dot as in dotupdate. That makes it hidden, but ls -a will reveal it.
Thanks Nickr!
Using Cyberduck (OSX FTP programme) there wasn't a .update folder there - I could see the other hidden folders like .cache .config .xbmc etc.
I created one with a dot before "update" and put the .tar file inside, rebooted and it's updated fine.
Am considering the i5 NUC (D54250WYK). Am I correct in thinking that I can connect a USB 2.0 hub with a usb 3.0 cable from the NUC and my usb 2.0 external drives will work properly?
Also, connect my HDMI 1.3a receiver with the 1.4 mini cable from the NUC?
(2014-04-08, 22:59)gcdlz Wrote: [ -> ]Am considering the i5 NUC (D54250WYK). Am I correct in thinking that I can connect a USB 2.0 hub with a usb 3.0 cable from the NUC and my usb 2.0 external drives will work properly?
No need for a USB 3.0 cable. The USB 3.0 sockets on the NUC are compatible with USB 2.0 cables, so you can plug in your USB 2.0 hub with a USB 2.0 cable into the NUC and it will work fine. USB 3.0 sockets on PCs are backwards compatible with USB 2.0 plugs on devices.
I plugged my Apple keyboard (which uses a standard USB 2.0 connector and has a USB 2.0 hub built in) into the NUC with no problem (and plugged my mouse into the integrated hub)
Quote:Also, connect my HDMI 1.3a receiver with the 1.4 mini cable from the NUC?
Yes. HDMI 1.4 is backwards compatible. You'll either need a Mini HDMI adaptor or a cable with a Mini HDMI plug to connect to the NUC. (There isn't a difference between HDMI 1.3a and HDMI 1.4 cables and connectors - it's just that HDMI 1.4 has a wider range of signal formats - i.e. higher pixel clocks - that can be supported if connected to HDMI 1.4 compatible kit. If connected to earlier versions of HDMI equipment it copes fine.)
(2014-04-08, 18:13)WilliamG Wrote: [ -> ] (2014-04-08, 14:21)frarev Wrote: [ -> ] (2014-04-08, 12:00)WilliamG Wrote: [ -> ]Question: What settings need to be enabled in XBMC for "pure" 24p from the Haswell NUC?
Which xbmc Will you install ? Windows ? Openelec ?
Thanks for your reply, information was very helpful.
(2014-04-08, 23:38)noggin Wrote: [ -> ] (2014-04-08, 22:59)gcdlz Wrote: [ -> ]Am considering the i5 NUC (D54250WYK). Am I correct in thinking that I can connect a USB 2.0 hub with a usb 3.0 cable from the NUC and my usb 2.0 external drives will work properly?
Hey guys, got my RAM for my i3 NUC today. XBMC/Plex works great, but I'm having huuuuuuge amounts of trouble getting my Harmony Ultimate to work. I have (by default) all the "regular" buttons working great - up/down/play/stop etc. But I can't get the "Info" button to be like pressing "I" on the keyboard to bring up the video information etc.
Does anyone have any tips on this? I had it working on my Mac just fine, but for some reason I can't seem to get anything to work on the Harmony aside from the default buttons that worked "out of the box."
Thanks in advance!
*Got it working*
Some help from here...
https://forums.plex.tv/index.php/topic/4...n-windows/
And... here...
http://andreperusse.com/be/post/2014/02/...ntrol.aspx
Combination of both sites got me running!
Now I just have ONE question remaining...
