Full Version: Intel NUC - Haswell (4th Generation CPU)
(2014-04-13, 21:32)javiertoti Wrote: [ -> ]How I should configure XBMC to play wmv and mkv files without issues?
With this files When I do a big step forrward/backward the video freezes for several seconds, it's quite annoying. Anyone knows how to fix it or can suggest me a right video configuration?
Thanks!!!
XBMC does play mkv files without issue. wmv I wouldn't touch with a barge pole so I am not sure. How about posting a debug log of the issue?
Most likely he runs over network and perhaps also uses wireless and expects a 100% correct seek of 5gb data within 0 seconds ...
what is best remote controller for inuc box ?
I am ether thinning about
harmony 650 http://www.amazon.com/Logitech-Harmony-R...1397426591 to cover all my devices with k400 keyboard.
or
f10 pro
http://www.amazon.com/Mele-Wireless-Keyb...1397426700&
what are your suggestion ?
I'l have windows 8 with xmbc, but I want also to be able to power on and off device and use remote control as a mouse for e.g netflix or hulu apps.
(2014-04-13, 22:53)nickr Wrote: [ -> ]
Thanks!!!
(2014-04-13, 23:38)fritsch Wrote: [ -> ]Most likely he runs over network and perhaps also uses wireless and expects a 100% correct seek of 5gb data within 0 seconds ...
I run my files over a wired lan (not wireless) but I have the same problem with my own recorded Tv Shows in the internal mSATA drive.
nickr, I've posted a debug for you in another post several days ago. Can you take a look?
http://forum.xbmc.org/showthread.php?tid=180265&page=7
I'm not very good with selecting debug code but I can make a video if it is useful.
Kind regards, and thanks again.
(2014-04-14, 00:09)macmus Wrote: [ -> ]what is best remote controller for inuc box ?
or
f10 pro
At the risk of sounding like a broken record... Any remote you want + a Flirc USB-dongle; this will let you map any button on the remote to any keyboard command. The only negative aspect would be that you need a small USB-dongle, which isn't big, though some people prefer not to have anything sticking out from their HTPC.
I don't know anything about the F10 pro, but the Harmony 650 is a very nice remote. I've been used the Harmony 300i earlier and now I use the Xbox 360 Media remote (black one)
I love the K400, but recently saw they have a new one K830 http://www.logitech.com/en-gb/product/li...board-k830
If it's similarly sized, then it might replace my K400, only drawback that may be a dealbreaker is that it uses recharchargeable battery that only lasts 10 days - you would need to charge it quite frequently.
Edit:
http://forum.xbmc.org/showthread.php?tid=186958 - this looks very nice, I could easily replace my current remote with this one since I never use the numbered buttons
This is the one I use, which will work without Flirc on the Intel NUC http://www.amazon.com/Xbox-360-Media-Rem...y_vg_img_y
The reason I decided to use a Flirc is because I couldn't map all the buttons - Flirc removes a lot of hassle.
the small x-box one looks nice!
How i can use it with windows 8.1, netflix metro app and acting as mouse. ?
The NUC IR receiver is able to work with pretty much any remote. I've tried a host of remote controls that I had and most of them do work (Samsung remotes I had did not work though). Of course you do need to find out the scan codes and do the keymapping. In my experience an MCE remote will work out of the box, though key mapping might be necessary in order to customize the behaviour of the remote to your liking.
Have a look at http://wiki.openelec.tv/index.php?title=...own_remote in order to use almost any remote with the NUC IR receiver, if you're using OpenELEC/Linux.
Keep in mind though, that if you want to power on the NUC from sleep/poweroff state, you need to be able to send an MCE power command (scancode 0x800ff40c) regardless of the OS.
i am not asking about linux configuration..
I will be running windows 8.1 as host system for my NUC. I want to be not only use xmbc but also all metro apps (maybe emulate cursor).
What is best is not case ?
How do I update the driver, in Openelec, for the Intel 7260 AC card? I thought it would be as simple as copying the newest version of iwlwifi-7260-8.ucode to /lib/firmware, but it's telling me that it's read only, despite the fact that I'm logged in as root (and the file is already +rw).
(2014-04-14, 13:53)mathgeek97 Wrote: [ -> ]How do I update the driver, in Openelec, for the Intel 7260 AC card? I thought it would be as simple as copying the newest version of iwlwifi-7260-8.ucode to /lib/firmware, but it's telling me that it's read only, despite the fact that I'm logged in as root (and the file is already +rw).
The system partition is actually a single file on the hard drive and is not writable. If there's a new firmware of the card, I think it would be best to contact the developers of the wlan-firmware package. Check here: https://github.com/OpenELEC/wlan-firmware (you can also make a pull request I think, but if you've never used git that might be a bit of a hike. Alternatively you could create a feature request in OE github…
I can see that iwlwifi-7260-8.ucode has actually been added there a month ago. Is there already a newer version of the same file? Which version of OE are you using?
This discussion actually goes off topic, so let's continue it on OpenELEC forums better? http://openelec.tv/forum/88-wlan
(2014-04-14, 09:56)macmus Wrote: [ -> ]i am not asking about linux configuration..
Not sure about the mouse... I just use Flirc, try to avoid using a mouse as I like things with tactile feedback. I.e. you can use them blindfolded.
(2014-04-14, 01:13)javiertoti Wrote: [ -> ]
Thanks!!!
setup: i5 with openElec alpha(feb.2014)
i had this Problem With WMV HD file ... 3 GB file size over a Gigabit ethernet link from my NAS every seek -> 1-3sec waiting ...
after a re-encoding to h.264 no problems ... mkv (with h.264 / mpeg4) also no problems Wink
PS: 20GB 4K movie files over network (h264) no problems with a delay or anything ... just smooth and instant
Hi everyone,
I finally got my NUC (34010) running the latest openelec (BETA 5) to suspend without waking up immediately.
In my case
echo GLAN > /proc/acpi/wakeup
seems to do the trick (it disables the GLAN ACPI device from triggering wake up).
As this setting does not survive a system start-up I added the above command to the autostart.sh script.
Sorry if this is old news but I don't have the patience to go through this entire thread to check Smile
Best,
Andrei
what about
http://www.amazon.com/gp/product/B00224Z...UTF8&psc=1
can i use build in irda with it ?
what about:
this can be used in build in netflix app in windows 8?
Or it's better I will have EventGhosts for that?
(2014-04-15, 20:16)andreig1978 Wrote: [ -> ]Hi everyone,
In my case
Best,
Andrei
Curious. I can't get OpenElec to suspend at all without crashing. Which BIOS version are you on?
