Full Version: Intel NUC - Haswell (4th Generation CPU)
Only "work around" for me is now to take a Custom Setting on TV/Beamer and tune it for the NUC with my Calibration Pictures, not 100% Spot on but probably enough for me till there is a better Solution...will try that tomorrow..
Anyway its frustrating even if i just have to change between Picture Modes if i want to use the Nuc..
I tried it with the latest nightlies from Gotham and it's not working there either.
(2013-11-15, 21:08)Selene Wrote: [ -> ]I tried it with the latest nightlies from Gotham and it's not working there either.
So, on Windows XBMC, there is no issue with the NUC?
I'm getting confused now.
Also, what version of Win are you running?
(2013-11-15, 22:52)adrian ballard Wrote: [ -> ]
I installed 7 and have no issues. It even boots quicker than OE. /shrug
I do have my OE set up backed up in case intel ever decides to fix it, but I guess it's a blessing for me, since now I can run emulators too and have them actually work.
Qsine has built solid enclosure for the raspberry pi. http://www.kickstarter.com/projects/1915...p?ref=live Big Grin
We are currently looking at the options to build something similar for the Nuc. It is still in the AutoCad phase, but once we have the design we will post it see if anybody can help us improve it
Looking at xbmc code, CalculateYUVMatrix() in xbmc/cores/VideoRenderers/VideoShaders/YUV2RGBShader.cpp makes me very suspicious. I think the translation by -16/255 should not be done and the order of scaling to full range and translating Cb and Cr should be reversed.
Overall, I don't like the way it's structured. Clearly the devs prefer full range output, but I think limited range is better quality. Full range with dithering or higher bpp may provide some benefit when processing is applied, but neither is currently supported.
With the limited range output messed up, it is difficult to demonstrate why it is better than full range. Good news is that if this is the problem, it should be easy to fix.
(2013-11-15, 23:23)lmyllari Wrote: [ -> ]Looking at xbmc code, CalculateYUVMatrix() in xbmc/cores/VideoRenderers/VideoShaders/YUV2RGBShader.cpp makes me very suspicious. I think the translation by -16/255 should not be done and the order of scaling to full range and translating Cb and Cr should be reversed.
Perhaps one of the developer threads, or a bug tracker post would get some dev attention.
Does any1 know about how hot the Haswell Nuc can get? We don't have Nuc unit to test yet. If the units gets really hot we will have to put that into consideration . We are trying to build a case that also act as heat sink.
(2013-11-15, 23:43)nickr Wrote: [ -> ]Perhaps one of the developer threads, or a bug tracker post would get some dev attention.
I'll look into it a little more and calculate the numbers. I'll file a bug/patch when I know what I'm talking about. Smile
Sounds great Big Grin
How is your picture quality? I have XBMC installed on i5 with Win 7 Home Premium ...it boots fine, Harmony remote works acceptable, but picture quality noticeable lower then my 4 year old Boxee box.
I didn't play with settings at all though, I'm new to XBMC/HTPC
(2013-11-15, 22:54)Selene Wrote: [ -> ]
(2013-11-16, 00:37)BuTbKa Wrote: [ -> ]How is your picture quality? I have XBMC installed on i5 with Win 7 Home Premium ...it boots fine, Harmony remote works acceptable, but picture quality noticeable lower then my 4 year old Boxee box.
(2013-11-15, 22:52)adrian ballard Wrote: [ -> ]So, on Windows XBMC, there is no issue with the NUC?
My picture quality is great. I'm running windows 7 ultimate. Keep in mind that you should probably download the drivers from the intel website.
I did downloaded and installed all the drivers, and updated BIOS as well.
When browsing web, looking trough Windows or XBMC menus quality is fine, but when playing HD movies from my NAS,,,,can see the difference between NUC and Boxee.
(2013-11-16, 01:06)BuTbKa Wrote: [ -> ]I did downloaded and installed all the drivers, and updated BIOS as well.
I'll check and report back but I'm 90% sure i dont have that issue.
Edit: I also have a 4 year old boxee Wink let you know how it works out.
Thanks Smile
