Hi. I am really interested in this plugin as I have tried XBMC in the past, but the lack of a Netflix plugin kept me from using it. Unfortunately, I can't get it to work for me. I am using Windows 7 64bit, logged on as local Administrator and UAC is turned off. I have the latest version of XMBC and latest version of your plugin. It appears to install just fine and I have verified my login info several times, but when I try to view My List, it shows "Working" for several seconds than displays "You are not logged on. Restart the add-on". I have tried rebooting, uninstalling the add-on and reinstalling it, all to no avail. I have tried installing Chrome and using it as the browser, same thing. Please help, thanks.
having same error. not logged in. seeing this in xbmc logs
21:38:54 T:4312 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiGenre%3fagid%3d6839%26pn%3d1%26np%3d1%26actionMethod%3djson
21:38:54 T:4312 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiGenre%3fagid%3d6839%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
21:38:54 T:4680 NOTICE: Thread Background Loader start, auto delete: false
21:38:59 T:3948 NOTICE: Previous line repeats 1 times.
21:38:59 T:3948 ERROR: Unable to find plugin
Same as Grimreaper319, "not logged in", tried clearing both cookies and cache.
(2014-02-27, 21:59)Grimreaper319 Wrote: [ -> ]Hi. I am really interested in this plugin as I have tried XBMC in the past, but the lack of a Netflix plugin kept me from using it. Unfortunately, I can't get it to work for me. I am using Windows 7 64bit, logged on as local Administrator and UAC is turned off. I have the latest version of XMBC and latest version of your plugin. It appears to install just fine and I have verified my login info several times, but when I try to view My List, it shows "Working" for several seconds than displays "You are not logged on. Restart the add-on". I have tried rebooting, uninstalling the add-on and reinstalling it, all to no avail. I have tried installing Chrome and using it as the browser, same thing. Please help, thanks.
I'm running this plugin on a Windows 7 64 bit, and having no real problem with it. When you say your running on the latest version of XBMC, is this Frodo 12.3, or are you refering to the latest "nightly" build? Cause if it's the latest "nightly" ... I'm not to sure if the plugin would work (but I could be wrong about that also).
Hi!
I also have the same problem as Grimreaper319 and the other posts above.
I am using latest addon version, 1.2.5, and latest stable XBMC release, Frodo, with Aeon Nox skin.
This is the content of the addon folder C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc:
resources (folder)
addon.xml
changelog.txt
default.py
download.py
LICENSE.txt
Here is the debug log, from starting NefliXBMC to trying to open the "HD only" category, which return the "not logged in" message:
12:00:32 T:6460 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
12:00:32 T:6460 DEBUG: Suspended the Sink
12:00:43 T:5268 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
12:00:44 T:5268 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
12:00:44 T:5268 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
12:00:45 T:5268 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://feeds.xbmc.org (easy=11C5CDF8, multi=053D5040)
12:00:52 T:5268 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
12:01:50 T:5268 DEBUG: ------ Window Init (Pointer.xml) ------
12:01:53 T:5268 DEBUG: CJoystick::Initialize : No Joystick found
12:01:53 T:5268 DEBUG: CWinEventsWin32::WndProcWindow is active
12:01:55 T:5268 DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
12:01:55 T:5268 DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
12:01:55 T:6460 DEBUG: Resumed the Sink
12:01:55 T:6460 DEBUG: CSoftAE::Run - Sink restart flagged
12:01:55 T:6460 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
12:01:55 T:5268 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:01:55 T:6460 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 1443164
12:01:55 T:6460 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
12:01:55 T:6460 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
12:01:55 T:6460 DEBUG: Audio Device : Speakers (High Definition Audio Device)
12:01:55 T:6460 DEBUG: Sample Rate : 44100
12:01:55 T:6460 DEBUG: Sample Format : AE_FMT_FLOAT
12:01:55 T:6460 DEBUG: Bits Per Sample : 32
12:01:55 T:6460 DEBUG: Valid Bits/Samp : 32
12:01:55 T:6460 DEBUG: Channel Count : 2
12:01:55 T:6460 DEBUG: Block Align : 8
12:01:55 T:6460 DEBUG: Avg. Bytes Sec : 352800
12:01:55 T:6460 DEBUG: Samples/Block : 32
12:01:55 T:6460 DEBUG: Format cBSize : 22
12:01:55 T:6460 DEBUG: Channel Layout : FL,FR
12:01:55 T:6460 DEBUG: Channel Mask : 3
12:01:55 T:6460 DEBUG: Frames : 441
12:01:55 T:6460 DEBUG: Frame Samples : 882
12:01:55 T:6460 DEBUG: Frame Size : 8
12:01:55 T:6460 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
12:01:55 T:6460 DEBUG: Output Device : Speakers - Speakers (High Definition Audio Device)
12:01:55 T:6460 DEBUG: Channel Layout: FL,FR
12:01:55 T:6460 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 4.1
12:01:55 T:6460 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
12:01:55 T:6460 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
12:01:55 T:5268 DEBUG: Keyboard: scancode: 48, sym: 0111, unicode: 0000, modifier: 0
12:01:55 T:5268 DEBUG: CApplication::OnKey: up (f080) pressed, action is Up
12:01:56 T:5268 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
12:01:56 T:5268 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
12:01:56 T:5268 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
12:01:56 T:5268 DEBUG: ParentPath = [addons://sources/video/]
12:01:56 T:6468 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','1','')
12:01:56 T:6468 INFO: initializing python engine.
12:01:56 T:6468 DEBUG: new python thread created. id=12
12:01:56 T:6468 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=12) plugin...
12:01:56 T:6764 NOTICE: Thread XBPyThread start, auto delete: false
12:01:56 T:6764 DEBUG: Python thread: start processing
12:01:56 T:6764 NOTICE: -->Python Interpreter Initialized<--
12:01:56 T:6764 DEBUG: XBPyThread::Process - The source file to load is C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py
12:01:56 T:6764 DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.chardet\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.requests\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.requests2\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
12:01:56 T:6764 DEBUG: XBPyThread::Process - Entering source directory C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc
12:01:56 T:6764 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
12:01:56 T:5268 DEBUG: ------ Window Init (DialogBusy.xml) ------
12:02:02 T:6764 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\resources\language\English, fallback to strings.xml
12:02:02 T:6468 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
12:02:02 T:6764 INFO: Scriptresult: Success
12:02:02 T:5268 DEBUG: Saving fileitems [plugin://plugin.video.netflixbmc/]
12:02:02 T:5268 DEBUG: -- items: 9, sort method: 0, ascending: false
12:02:02 T:2244 NOTICE: Thread Background Loader start, auto delete: false
12:02:02 T:6764 INFO: Python script stopped
12:02:02 T:6764 DEBUG: Thread XBPyThread 6764 terminating
12:02:02 T:5268 DEBUG: waiting for python thread 12 (C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py) to stop
12:02:02 T:5268 DEBUG: python thread 12 (C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py) destructed
12:02:02 T:2244 DEBUG: Thread Background Loader 2244 terminating
12:02:02 T:5268 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
12:02:03 T:5268 DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
12:02:03 T:5268 DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
12:02:04 T:5268 DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
12:02:04 T:5268 DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
12:02:06 T:5268 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
12:02:06 T:5268 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
12:02:06 T:5268 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiHD%3fdev%3dPC%26pn%3d1%26np%3d1%26actionMethod%3djson)
12:02:06 T:5268 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
12:02:06 T:7064 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','2','?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiHD%3fdev%3dPC%26pn%3d1%26np%3d1%26actionMethod%3djson')
12:02:06 T:7064 INFO: initializing python engine.
12:02:06 T:7064 DEBUG: new python thread created. id=13
12:02:06 T:7064 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=13) plugin...
12:02:06 T:5480 NOTICE: Thread XBPyThread start, auto delete: false
12:02:06 T:5480 DEBUG: Python thread: start processing
12:02:06 T:5480 NOTICE: -->Python Interpreter Initialized<--
12:02:06 T:5480 DEBUG: XBPyThread::Process - The source file to load is C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py
12:02:06 T:5480 DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.chardet\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.requests\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.requests2\lib;C:\Users\Raoden\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python26.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages;
12:02:06 T:5480 DEBUG: XBPyThread::Process - Entering source directory C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc
12:02:06 T:5480 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
12:02:06 T:5268 DEBUG: ------ Window Init (DialogBusy.xml) ------
12:02:08 T:5480 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\resources\language\English, fallback to strings.xml
12:02:08 T:5480 INFO: Scriptresult: Success
12:02:08 T:5268 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
12:02:08 T:5480 INFO: Python script stopped
12:02:08 T:5480 DEBUG: Thread XBPyThread 5480 terminating
12:02:08 T:5268 DEBUG: waiting for python thread 13 (C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py) to stop
12:02:08 T:5268 DEBUG: python thread 13 (C:\Users\Raoden\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py) destructed
12:02:08 T:7064 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
12:02:08 T:5268 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiHD%3fdev%3dPC%26pn%3d1%26np%3d1%26actionMethod%3djson
12:02:08 T:5268 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiHD%3fdev%3dPC%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
12:02:08 T:5268 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
12:02:08 T:5268 DEBUG: ParentPath = [addons://sources/video/]
12:02:08 T:5268 DEBUG: Loading fileitems [plugin://plugin.video.netflixbmc/]
12:02:08 T:5268 DEBUG: -- items: 9, directory: plugin://plugin.video.netflixbmc/ sort method: 0, ascending: false
12:02:08 T:4596 NOTICE: Thread Background Loader start, auto delete: false
12:02:08 T:4596 DEBUG: Thread Background Loader 4596 terminating
12:02:08 T:5268 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
12:02:09 T:5268 DEBUG: ------ Window Init (Pointer.xml) ------
12:02:10 T:5268 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(playercontrols)
12:02:10 T:5268 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(playercontrols)
12:02:10 T:5268 DEBUG: Activating window ID: 10114
12:02:10 T:5268 DEBUG: ------ Window Init (PlayerControls.xml) ------
12:02:10 T:5268 INFO: Loading skin file: PlayerControls.xml, load type: KEEP_IN_MEMORY
12:02:10 T:5268 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
12:02:10 T:5268 DEBUG: CApplication::ExecuteXBMCAction : Translating Dialog.Close(1121)
12:02:10 T:5268 DEBUG: CApplication::ExecuteXBMCAction : To Dialog.Close(1121)
12:02:10 T:5268 DEBUG: CApplication::ExecuteXBMCAction : Translating Dialog.Close(playercontrols)
12:02:10 T:5268 DEBUG: CApplication::ExecuteXBMCAction : To Dialog.Close(playercontrols)
12:02:10 T:5268 DEBUG: ------ Window Deinit (PlayerControls.xml) ------
12:02:11 T:5268 DEBUG: CWinEventsWin32::WndProcWindow is active
Please help! Really want this to work! :-D
PS: I'm using Norwegian Netflix from Norway, no proxy/vpn service, if that matters.
Is anybody's plugin working at this time? It seems strange that a number of us are having issues with the login error. I just installed it so mine never worked correctly. Not sure if other folks had it successfully working and then got the errors or if these errors are related to all new installs
I installed the plugin 1-2 weeks ago on 2 htpc's, both running windows 7 ultimate 64 bit and frodo 12.3.
I checked them yesterday, and no problems as these last few posts comment.
And I'm using the Norwegian Netflix, just as Raoden above.
P.S. I've only ever opened the "My List" tab in Netflix, as I tend to use the Netflix App on the Ipad to find things I want to watch and add them to "My List".
I cleared my cache and cookies as well, to no avail.
(2014-02-28, 16:03)Verderer Wrote: [ -> ]I installed the plugin 1-2 weeks ago on 2 htpc's, both running windows 7 ultimate 64 bit and frodo 12.3.
Verderer, which version of the plugin have you got running?
Hello, I stumbled across this great project on Tuesday. I've got pipe running, I've got the addons in, chrome, netflix, and my user information. I'm sure I missed something simple. I'm running lbuntu. I'm certainly a novice at most of anything outside apache, php, mysql. When launching netflixbmc I receive an initial error stating that you are not logged in. Restart addon when clicking my list. Then I get a script failed: plugin.video.netflixbmc. Version 1.25. Chrome 1.1. I'm sure this is something very simple I'm missing here.
EDIT: Additionally, I do have Netflix working through Chrome UA spoofer. It would be nice to see it running in xbmc since I use my old htc inspire as a remote for it. Though the VNC isn't so bad either.
i will try older versions if I can get them
(2014-02-28, 15:09)rlefig Wrote: [ -> ]Is anybody's plugin working at this time? It seems strange that a number of us are having issues with the login error. I just installed it so mine never worked correctly. Not sure if other folks had it successfully working and then got the errors or if these errors are related to all new installs
I'm using this plug in with no problems. I'm running Windows 7 64 and Frodo 12.3.
Thanks scrolling, I would like to get this working badly as my son will be going in for his 2nd hip operation and an esy netflix would be beneficial to him.
I am using win7 x64 Frodo 12.2. I do have PlayOn that I purchased to run netflix but it is cumbersome on the win7. I just downloaded netflixbmc v 1.2.5 but just can not get past that error.
Same problem as many above. Just downloaded the latest xbmc. Netflixbmc does not work. Says "you are not logged in", even though log-in details are correct. I really need this to work, I'm trying to set netflix up for my grandfather on the TV, and it's pretty much the only remote-controlled solution for Netflix available on Windows (already tried WMC, doesn't work in portuguese).
BTW, I'm using Brazilian Netflix. My password has an uppercase character (which Netflix does differentiate), but I tried changing it to a plain lowercase one, clearing cache but it kept returning the "you are not logged in" error.
Netflix opens just fine on Chrome.
Help! ;_;
(2014-02-28, 20:10)scrolling Wrote: [ -> ] (2014-02-28, 15:09)rlefig Wrote: [ -> ]Is anybody's plugin working at this time? It seems strange that a number of us are having issues with the login error. I just installed it so mine never worked correctly. Not sure if other folks had it successfully working and then got the errors or if these errors are related to all new installs
scrolling, which version of the NetfliXBMC addon are you using?
