Full Version: WinLIRC XBMC client
Pages: 1 2
This is great! I've had this Hauppauge Win-TV card for years but haven't even had in my computer for a long time because I didn't think it served any purpose (the original reason: to watch TV- is no longer needed). Until I saw something somewhere about the remote & various things that could be done with it. So I plugged in the card and hooked up the remote and VOILA- like magic: ALL kinds of cool, new possibilities available!
I LOVE IT!
So, I'm wondering: is it possible to use my remote for other functions that you have not listed? Possibly by changing the xml file directly?
My remote has a "Mute" button; and I would like to use it for that purpose, just for XBMC. But I do not see that command on the list...
Thank you so much!
It works in KODI 15! Thanks.
Only pause button doesn't work...... Can you fix itHuh
How to automatic taskkill "Keymap.exe" process after close KodiHuh
(translate.google)
I open keymap.exe at windows start and if I close kodi I keep keymap.exe open. Why do you want to close keymap.exe?
(2015-08-15, 16:46)capoccia Wrote: [ -> ]It works in KODI 15! Thanks.
You may try to edit the keymap.xml
<p>Play</p> to <p>playpause</p>
Can anybody confirm, that this no longer works with Kodi 17?
Pages: 1 2
