Full Version: Problem Live TV - Mediaportal Server 1.2.3 and RasPi
Hi guys,
maybe someone can help me, i have a Raspberry Pi Model B version and installed first Xbian and than Raspbmc.
Both with the same problem - i can not start Live TV without any problems. Sometimes it worked mostly not.
I can play already recorded movies without any problems but i can not start Live TV. Most of the time when i try to start Live TV, XBMC crash to the console or restarts.
I tried it with the TSReader (which i prefer) and also with the ffmpeg streaming method - both are not working.
Here are some logfiles:
Xbian directly after the crash.
http://pastebin.com/7NPXqFP8
Xbian dmesg before the crash:
http://pastebin.com/1iAPxnnW
and after the crash:
http://pastebin.com/YYvhQ8qm
Raspbmc:
http://pastebin.com/m7LFpzhN
In Raspbmc i tried Live TV directly after the installation with a SD channel and it worked. Than i switched to an HD channel and the system crashed. After the restart i tried again the SD channel and the system restarted again and i was not able to run Live TV anymore.
Another test was to add the timeshift folder from the server to the XBMC videofolder, i started manually timeshift on the server and opened the .ts timeshift file. XBMC was able to play the file without any problems.
I can't help you with RPi related problems. I don't have one.
With respect to the crashes in "ffmpeg" mode: it is XBMC itself that is doing the RTSP stream playback, not the PVR addon, so the XBMC+ffmpeg library combination is causing troubles here.
thx for the answer, the strange thing is when i start timeshift manually on the server than i can open the timeshift file in the videofolder without any problems. But when i start the timeshift file with LiveTV in XBMC, RaspPi crash all the time.
I will see if I can borrow my friends RPi in the coming month for a crash/debugging session...
already solved the problem - as you said it was not your Addon - updated everything - Firmware, Software etc. in the end it worked
