Full Version: Can't load xbmc getting errors
I have a ATV2 running 4.4.4, which had xbmc giving me problems so update xbmc but kept on getting errors. So I decided to delete xbmc. Now I am trying to put it back and I can't I have used every trick in the book but starting out fresh. I keep getting these errors using the Nito tv install and from using putty.
Apple-TV:~ root# http://cydia.saurik.com/tss@home/api/check/$ECID
-sh: http://cydia.saurik.com/tss@home/api/check/: No such file or directory
Apple-TV:~ root# apt-get remove org.xbmc.xbmc-atv2
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package org.xbmc.xbmc-atv2 is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
W: Encountered a section with no Package: header
W: You may want to run apt-get update to correct these problems
Apple-TV:~ root# apt-get autoremove
Apple-TV:~ root# rm -Rf /private/var/mobile/Library/Preferences/XBMC
Apple-TV:~ root# rm -Rf /private/var/stash/Applications/XBMC.frappliance
Apple-TV:~ root# echo "deb http://www.ambertation.de ./downloads/PLEX/" > /etc/a pt/sources.list.d/plex.list
Apple-TV:~ root# apt-get update
Hit http://apt.thebigboss.org stable Release.gpg
Hit http://apt.saurik.com ios/675.00 Release.gpg
Hit http://cydia.zodttd.com stable Release.gpg
Get:1 http://nitosoft.com Release.gpg [487B]
Hit http://apt.modmyi.com stable Release.gpg
Ign http://mirrors.xbmc.org ./ Release.gpg
Ign http://www.ambertation.de ./downloads/PLEX/ Release.gpg
Hit http://apt.awkwardtv.org stable Release.gpg
Hit http://nitosoft.com Release
Hit http://apt.thebigboss.org stable/main Packages/DiffIndex
Ign http://www.ambertation.de ./downloads/PLEX/ Packages/DiffIndex
Ign http://mirrors.xbmc.org ./ Packages/DiffIndex
Err http://nitosoft.com Release
Ign http://apt.saurik.com ios/675.00/main Packages/DiffIndex
Hit http://cydia.zodttd.com stable/main Packages/DiffIndex
Hit http://apt.modmyi.com stable/main Packages/DiffIndex
Hit http://www.ambertation.de ./downloads/PLEX/ Packages
Hit http://mirrors.xbmc.org ./ Packages
Hit http://apt.saurik.com ios/675.00/main Packages
Get:2 http://nitosoft.com Release [295B]
Hit http://apt.awkwardtv.org stable/main Packages/DiffIndex
Ign http://nitosoft.com Release
Ign http://nitosoft.com Packages/DiffIndex
Hit http://nitosoft.com Packages
Fetched 782B in 3s (220B/s)
[b]W: GPG error: http://nitosoft.com Release: The following signatures were invali d: KEYEXPIRED 1355702829 KEYEXPIRED 1355702829 KEYEXPIRED 1355702829
No matter what I do I get this message.
I also get this with this.
Apple-TV:~ root# apt-get install org.xbmc.xbmc-atv2
The following extra packages will be installed:
bash beigelist bsdiff bzip2 com.nito.updatebegone com.saurik.substrate.safemode coreutils
coreutils-bin curl diffutils dpkg findutils gawk grep gzip lzma mobilesubstrate ncurses
openssl org.xbmc.xbmc-seatbeltunlock profile.d readline sed tar
The following NEW packages will be installed:
openssl org.xbmc.xbmc-atv2 org.xbmc.xbmc-seatbeltunlock profile.d readline sed tar
0 upgraded, 25 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B/51.4MB of archives.
After this operation, 24.4MB of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
org.xbmc.xbmc-seatbeltunlock org.xbmc.xbmc-atv2
Install these packages without verification [y/N]? y
E: Couldn't configure pre-depend dpkg for grep, probably a dependency cycle.
you 're not alone. I attemp to fix but failed, can't remove or install. really pain in the ASS
