Full Version: [XBMC Subtitles] depedencies not met
I Want to install the XBMC subtitles add-on, but it says it is "broken" because the dependencies aren't met. Now, the description says that i have to set the path to XBMC subtitles under system > skin > add-on scripts (+ make sure the Subs-button is on, but that's done). I can't find that menu however and don't know what to do next.
3 hours of searching the web only taught me that 1Channel and Icefilms might cause trouble.
Anyone who knows how I can change this settings properly and run the sub-add-on?
I have Mac OS X 10.7.5 and Frodo…
Greetz!
I have the same. I installed xbmc at the weekend, and SuperRepo last night.
I'm a n00b at this stuff - what should I do? Uninstall SuperRepo?
Well, my problem was suddenly solved a few days ago. I tried searching for subs like I usually do when i'm on my gf's computer and it suddenly worked. I did not change any settings since I started this thread so my best advice is: keep trying, if you're lucky it'll work sometime and keep working.
Good luck!
(2014-01-14, 17:01)ocb70 Wrote: [ -> ]I have the same. I installed xbmc at the weekend, and SuperRepo last night.
Indeed start with uninstalling it.
