Is it possible to edit an .xml-file in Amber and add:
System.CPUTemperature and System.GPUTemperature labels so I can see the Rapberry Pi Temperatures below the Clock (top right corner)?
You can put it on all the menus by editing Includes.xml.
Locate the following:
PHP Code:
<label>$VAR[Time]</label>
</control>
And paste this after it:
PHP Code:
<control type="label">
<posx>130r</posx>
<posy>30</posy>
<width>300</width>
<height>50</height>
<align>left</align>
<font>Details</font>
<textcolor>White</textcolor>
<shadowcolor>ShadowDark</shadowcolor>
<label>CPU: $INFO[System.CPUTemperature]</label>
</control>
<posx>130r</posx>
<posy>60</posy>
<width>300</width>
<height>50</height>
<align>left</align>
<label>GPU: $INFO[System.GPUTemperature]</label>
</control>
If you want it on the pause screen you will also need to edit DialogSeekBar.xml.
PHP Code:
<label>$INFO[System.Time]</label>
</control>
And paste the same code above after it.
Thank YOU very much.. That´s what I was looking for...
Very cool..
Pretty sure there is only one temperature sensor for both the CPU and GPU on a Raspberry Pi, as it's a SoC rather than discrete CPU and GPU silicon. Any difference in the readings is likely due to timing differences resulting from when the single temperature sensor is read out. For example:
rpi512:~ # cat /sys/class/thermal/thermal_zone0/temp && cat /sys/class/thermal/thermal_zone0/temp
59451
58376
Same sensor, two significantly different readings, only milliseconds apart.
If you want to monitor the Raspberry Pi statistics, there's
this script (bcmstat.sh) which will show you the temperature (amongst other things) but runs under ssh so not as pretty as having it in the GUI (but far more informative!)
your right! GPU.Temerature only shows "?"
So I only implemented CPU.Temperature..
I will try your script as well, Millhouse.. ty very much..
You all do a great job that the RPi becomes more and more popular as a Mediacenter..
oh man how can i run the bcmstat script..
I tried it via your github but I´m a noob.. how can i run it with putty?!
(2014-01-19, 20:38)Ruschi Wrote: [ -> ]oh man how can i run the bcmstat script..
Depending on what distribution you are using (Raspbmc or OpenELEC), "install" as follows:
Raspbmc:
cd ~ && wget --no-check-certificate https://raw2.github.com/MilhouseVH/bcmstat/master/bcmstat.sh && chmod +x ./bcmstat.sh
OpenELEC:
cd ~ && curl https://raw2.github.com/MilhouseVH/bcmstat/master/bcmstat.sh -o ./bcmstat.sh && chmod +x ./bcmstat.sh
To view help:
Example command:
x: monitor extended stats (cpu load and memory)
g: monitor GPU memory
c: enable colourisation
d10: 10 second interval
To make "xgcd10" the default setting:
echo "xgcd10" > ~/.bcmstat.conf
Now just run:
ty very much for your help... I got it.. Nice script..
OpenELEC_Gotham (Milhouse) Version: devel-20140117222505-r17035-g9d596bb my Version :-)
Make it a bit more fit the skin...
Locate the following in
Includes.xml:
PHP Code:
And paste this OVER it:
PHP Code:
<label>$VAR[Time][COLOR=Orange] • [/COLOR]CPU: $INFO[System.CPUTemperature]</label>
DialogSeekBar.xml:
PHP Code:
PHP Code:
<label>$INFO[System.Time][COLOR=Orange] • [/COLOR]CPU: $INFO[System.CPUTemperature]</label>
Just a noob trying to understand here; can you tell me what function '•' has in your script? With that i see the cpu temp ok but before that: •, when i delete '•' from the script cpu temp is showing ok so a bit confused what the use is. Thx in advance !
You can use "-" (without quotes) instead.
so.. no use, just eye-candy?
(2014-01-28, 11:15)botribun Wrote: [ -> ]Make it a bit more fit the skin...
Locate the following in Includes.xml:
PHP Code:
PHP Code:
Locate the following in DialogSeekBar.xml:
PHP Code:
PHP Code:
great!!
is it possible to also add CPU load beside temp and what will code be for this?
.....Anyone know command for cpu load?.....
