Hi Downloaded the ace skin for xbmc and I cannot find navi-x in it, I have unistalled xbmc and and reinstall and still I have the ace skin how can I revert back to the orginal skin or find nav-x on the ace skin, usin Ipad 1 jailbroken
please any help would be great
Navi is not a part of a skin or xbmc is an addon you will never found it, search on google for navy-x add on
(2014-01-08, 13:56)warlion Wrote: [ -> ]Navi is not a part of a skin or xbmc is an addon you will never found it, search on google for navy-x add on
Hi I used the add-on from zip file and enabled it, but from the menus of the ace skin I cannot find it?
Video Add-ons
Settings - skin settings - main menu -customize main menu
You can add the addon any place you want just select the menu you want to choose and press left
+add-on item click
Select the new space add on and select the add on to add it to the sub menu
BTW to change the skin go to settings - appearance - skin
To change to another skin
I think it's in program addons not video addons
(2014-01-08, 16:07)warlion Wrote: [ -> ]Video Add-ons
+add-on item click
Hello I need to add all the Group "programm-addons" in main menĂ¹ and not only one addon.
How Can I Do?
It's too strange that there's not any link at "programm-addons" !!!
Now I Can'T Use "Programm-addons" because there is no connection anywhere in the skin to "programm-addons"
It 'an oversight or am I that I can not find the link?
Thanks in advance.
