Full Version: Constant Buffering - Log File Posted
Everything has been running perfect until this past Saturday when it started taking an extremely long time to scan for new media. Once it finally finsihed I can start a movie but then a few minutes in, the buffering every few minutes begins.
I have not changed anything since I started using Frodo 12.2 other than adding a NAS earlier this month which has been running flawlessly.
I have not changed any setting within XBMC so I don't know why this all of a sudden started.
I've read other posts but never an answer that I have not already done when I originally setup XBMC.
I did read on a post to clear cache but no instructions where to clear the cache.
System Specs:
Windows 7 64-bit
Wifi connection over 802.11ac.
I'm using a Synology NAS. I mapped the drives on the HTPC and used those mapped drives in XBMC.
@billybobjimbojr,
Quote:Wifi connection over 802.11ac.
Be aware of the inherent limitations of 802.11xx; and how susceptible it is to interference, collisions, etc.
Can you try running a cat5/6{e} cable from your router/switch to your XBMC client and see if you get any improvement. Also, there is an old widget for Windows 7 that show your network connection (strength, etc). Try to run XMBC as a small window (not Full Screen) while the widget is running (both wireless and wired). This will tell you if there is a correlation with your buffering and a network congestion...
I resolved my problem.
I had started the Media Server within the Synology NAS so my son could watch movies from the PS3. For some reason XBMC would constantly buffer even though the NAS had little to no CPU or RAM usage when I would try to watch something on my HTPC. Anyway, stopping the Media Server fixed it. I hope this helps others that may be having similar issues.
I thought I resolved my problem but the buffering and or pausing have started back. It's weird, sometimes I can watch a movie and it works fine all the way through and other times it's every 10min all the way through the movie.
Where should I start first trying to figure this out? It has happened on every version of XBMC that I've used starting with Eden but it wasn't as bad in Eden as it is now with Frodo 12.3
I guess I need to post a log file, where do I turn it on and what directory does it post to?
Have you tested on a wired connection yet ?
99% of these kinds of problems are because of the wireless connection if that's what's being used.
And no, it does not matter if it worked before.
You need to connect your NAS to your HTPC with a Gigabit ethernet cable and confirm if you are having the same buffering issues or not.
If you are, we can look at other things, but if not, it's the WiFi. Which would not surprise me in the slightest.
I think it's resolved now.
The advancedsettings.xml file was missing. Now that it's back, the buffering has disappeared over the last few days.
I spoke too soon.
Here is my log file. Can someone take a look?
18:04:49 T:3784 NOTICE: -----------------------------------------------------------------------
18:04:49 T:3784 NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Windows 7 SP1 64-bit, build 7601. Built on Dec 19 2013 (compiler 1600)
18:04:49 T:3784 NOTICE: Intel® Atom™ CPU D525 @ 1.80GHz
18:04:49 T:3784 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
18:04:49 T:3784 NOTICE: Running with administrator rights
18:04:49 T:3784 NOTICE: Aero is enabled
18:04:49 T:3784 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
18:04:49 T:3784 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
18:04:49 T:3784 NOTICE: special://masterprofile/ is mapped to: C:\Users\HTPC\AppData\Roaming\XBMC\userdata
18:04:49 T:3784 NOTICE: special://home/ is mapped to: C:\Users\HTPC\AppData\Roaming\XBMC\
18:04:49 T:3784 NOTICE: special://temp/ is mapped to: C:\Users\HTPC\AppData\Roaming\XBMC\cache
18:04:49 T:3784 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
18:04:49 T:3784 NOTICE: Local hostname: XBMC
18:04:49 T:3784 NOTICE: Log File is located: C:\Users\HTPC\AppData\Roaming\XBMC\xbmc.log
18:04:49 T:3784 NOTICE: Found 2 Lists of Devices
18:04:49 T:3784 NOTICE: Enumerated DirectSound devices:
18:04:49 T:3784 NOTICE: Device 1
18:04:49 T:3784 NOTICE: m_deviceName : {99212238-38A4-4570-A35D-C198A2D35109}
18:04:49 T:3784 NOTICE: m_displayName : HDMI - M470NV-1 (NVIDIA High Definition Audio)
18:04:49 T:3784 NOTICE: m_displayNameExtra: DirectSound: M470NV-1 (NVIDIA High Definition Audio)
18:04:49 T:3784 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:04:49 T:3784 NOTICE: m_channels : FL,FR
18:04:49 T:3784 NOTICE: m_sampleRates : 48000
18:04:49 T:3784 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
18:04:49 T:3784 NOTICE: Device 2
18:04:49 T:3784 NOTICE: m_deviceName : {AA0F9EE3-E974-427D-BE26-136D3AF88924}
18:04:49 T:3784 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (High Definition Audio Device)
18:04:49 T:3784 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device)
18:04:49 T:3784 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:04:49 T:3784 NOTICE: m_sampleRates : 44100
18:04:49 T:3784 NOTICE: Enumerated WASAPI devices:
18:04:49 T:3784 NOTICE: m_displayNameExtra: WASAPI: M470NV-1 (NVIDIA High Definition Audio)
18:04:49 T:3784 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:04:49 T:3784 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (High Definition Audio Device)
18:04:49 T:3784 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100,32000
18:04:49 T:3784 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FM​T_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:04:49 T:3784 NOTICE: load settings...
18:04:49 T:3784 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:04:49 T:3784 NOTICE: loading special://masterprofile/guisettings.xml
18:04:49 T:3784 NOTICE: Getting hardware information now...
18:04:49 T:3784 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:04:49 T:3784 NOTICE: Loaded playercorefactory configuration
18:04:49 T:3784 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:04:49 T:3784 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:04:49 T:3784 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:04:49 T:3784 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
18:04:49 T:3784 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<network>
<cachemembuffersize>104857600</cachemembuffersize>
</network>
</advancedsettings>
18:04:49 T:3784 NOTICE: Default DVD Player: dvdplayer
18:04:49 T:3784 NOTICE: Default Video Player: dvdplayer
18:04:49 T:3784 NOTICE: Default Audio Player: paplayer
18:04:49 T:3784 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:04:49 T:3784 NOTICE: Log level changed to 0
18:04:49 T:3784 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:04:50 T:1552 NOTICE: Thread CSoftAE start, auto delete: false
18:04:50 T:3784 NOTICE: Running database version Addons15
18:04:50 T:1960 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:04:50 T:4180 NOTICE: Previous line repeats 1 times.
18:04:50 T:4180 NOTICE: Thread CRemoteControl start, auto delete: false
18:04:50 T:3784 NOTICE: Found screen: Generic PnP Monitor on NVIDIA ION , adapter 0.
18:04:50 T:3784 NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Previous line repeats 2 times.
18:04:51 T:3784 NOTICE: Additional mode: 720x576 @ 72.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 720x576 @ 75.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 800x600 @ 72.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1024x768 @ 70.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1152x864 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1152x864 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1152x864 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1152x864 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1152x864 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1176x664 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1176x664 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x768 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x768 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x768 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x768 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x768 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x800 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x800 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x800 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x800 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x800 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x960 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x960 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x960 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x960 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x960 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x1024 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x1024 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x1024 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x1024 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1280x1024 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1360x768 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1360x768 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1360x768 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1360x768 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1360x768 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1366x768 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1366x768 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1366x768 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1366x768 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1366x768 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x900 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x900 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x900 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x900 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x900 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x1024 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x1024 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x1024 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x1024 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x1024 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1600x1024 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1680x1050 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1680x1050 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1680x1050 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1680x1050 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1680x1050 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1768x992 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1768x992 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 24.00 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 23.98 - Full Screen
18:04:51 T:3784 NOTICE: Additional mode: 1920x1080 @ 50.00 - Full Screen
18:04:51 T:3784 NOTICE: Checking resolution 16
18:04:53 T:3784 NOTICE: Running database version Addons15
18:04:53 T:3784 NOTICE: Running database version ViewModes4
18:04:53 T:3784 NOTICE: Running database version Textures13
18:04:53 T:3784 NOTICE: Running database version MyMusic32
18:04:53 T:3784 NOTICE: Running database version MyVideos75
18:04:53 T:3784 NOTICE: Running database version TV22
18:04:53 T:3784 NOTICE: Running database version Epg7
18:04:53 T:3784 NOTICE: initializing playlistplayer
18:04:53 T:3784 NOTICE: DONE initializing playlistplayer
18:04:54 T:4380 NOTICE: Thread XBPyThread start, auto delete: false
18:04:54 T:3784 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
18:04:54 T:4380 NOTICE: -->Python Interpreter Initialized<--
18:04:54 T:5064 NOTICE: Thread CVideoInfoScanner start, auto delete: false
18:04:54 T:3784 NOTICE: initialize done
18:04:54 T:4444 NOTICE: Thread XBPyThread start, auto delete: false
18:04:55 T:3784 NOTICE: Running the application...
18:04:55 T:1104 NOTICE: Thread Jobworker start, auto delete: true
18:04:55 T:4444 NOTICE: -->Python Interpreter Initialized<--
18:04:55 T:3784 NOTICE: ES: Starting event server
18:04:55 T:4348 NOTICE: Thread CEventServer start, auto delete: false
18:04:55 T:4348 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:04:55 T:4348 NOTICE: UDP: Listening on port 9777
18:04:55 T:4356 NOTICE: Thread CTCPServer start, auto delete: false
18:04:55 T:5064 NOTICE: VideoInfoScanner: Starting scan ..
18:04:55 T:4800 NOTICE: Thread Jobworker start, auto delete: true
18:04:56 T:1900 NOTICE: Thread CFileCache start, auto delete: false
18:04:56 T:4444 NOTICE: StorageServer Module loaded RUN
18:04:56 T:4444 NOTICE: StorageClient-2.5.4 Starting server
18:04:56 T:4444 NOTICE: StorageServer-2.5.4 Storage Server starting C:\Users\HTPC\AppData\Roaming\XBMC\cache\commoncache.db
18:05:00 T:3320 NOTICE: Thread CFileCache start, auto delete: false
18:06:19 T:676 NOTICE: Thread Jobworker start, auto delete: true
18:06:41 T:5064 NOTICE: Previous line repeats 1 times.
18:06:41 T:5064 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 01:46
18:10:02 T:2900 NOTICE: Thread Jobworker start, auto delete: true
18:10:07 T:4196 NOTICE: Previous line repeats 2 times.
18:10:07 T:4196 NOTICE: Thread Background Loader start, auto delete: false
18:10:30 T:3784 NOTICE: DVDPlayer: Opening: S:\Over the Hedge (2006)\Over the Hedge (2006).mkv
18:10:30 T:3784 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:10:30 T:4092 NOTICE: Thread CDVDPlayer start, auto delete: false
18:10:30 T:4092 NOTICE: Creating InputStream
18:10:30 T:4092 NOTICE: Creating Demuxer
18:10:31 T:4092 NOTICE: Opening video stream: 0 source: 256
18:10:31 T:4092 NOTICE: Creating video codec with codec id: 28
18:10:31 T:4092 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:10:31 T:4092 NOTICE: Creating video thread
18:10:31 T:4092 NOTICE: Opening audio stream: 1 source: 256
18:10:31 T:4092 NOTICE: Finding audio codec for: 86019
18:10:31 T:4092 NOTICE: Creating audio thread
18:10:31 T:4364 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
18:10:31 T:4364 NOTICE: running thread: video_thread
18:10:31 T:3704 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
18:10:31 T:3704 NOTICE: running thread: CDVDPlayerAudio::Process()
18:10:31 T:3704 NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
18:10:31 T:4364 NOTICE: fps: 25.000000, pwidth: 720, pheight: 404, dwidth: 717, dheight: 404
18:10:31 T:4364 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
18:10:31 T:4364 NOTICE: D3D: rendering method forced to DXVA2 processor
18:11:31 T:4348 NOTICE: ES: Client from 127.0.0.1 timed out
18:16:33 T:3704 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:16:34 T:4364 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:17:33 T:3704 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:17:34 T:4364 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:17:34 T:4092 NOTICE: CDVDPlayer::OnExit()
18:17:34 T:4092 NOTICE: DVDPlayer: eof, waiting for queues to empty
18:17:34 T:4092 NOTICE: DVDPlayer: closing audio stream
18:17:34 T:4092 NOTICE: Closing audio stream
18:17:34 T:4092 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
18:17:34 T:4092 NOTICE: Waiting for audio thread to exit
18:17:34 T:3704 NOTICE: thread end: CDVDPlayerAudio::OnExit()
18:17:34 T:4092 NOTICE: Closing audio device
18:17:34 T:4092 NOTICE: Deleting audio codec
18:17:34 T:4092 NOTICE: DVDPlayer: closing video stream
18:17:34 T:4092 NOTICE: Closing video stream
18:17:34 T:4092 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
18:17:34 T:4092 NOTICE: waiting for video thread to exit
18:17:34 T:4364 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
18:17:34 T:4364 NOTICE: thread end: video_thread
18:17:34 T:4092 NOTICE: deleting video codec
18:17:34 T:4092 NOTICE: CDVDPlayer::OnExit() deleting demuxer
18:17:34 T:4092 NOTICE: CDVDPlayer::OnExit() deleting input stream
18:17:34 T:1152 NOTICE: Thread Background Loader start, auto delete: false
18:17:34 T:3784 NOTICE: CDVDPlayer::CloseFile()
18:17:34 T:3784 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:17:34 T:3784 NOTICE: DVDPlayer: waiting for threads to exit
18:17:34 T:3784 NOTICE: DVDPlayer: finished waiting
18:17:34 T:2212 NOTICE: Thread Jobworker start, auto delete: true
18:17:42 T:3784 NOTICE: DVDPlayer: Opening: S:\Over the Hedge (2006)\Over the Hedge (2006).mkv
18:17:42 T:3784 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:17:42 T:4992 NOTICE: Thread CDVDPlayer start, auto delete: false
18:17:42 T:4992 NOTICE: Creating InputStream
18:17:43 T:4992 NOTICE: Creating Demuxer
18:17:43 T:4992 NOTICE: Opening video stream: 0 source: 256
18:17:43 T:4992 NOTICE: Creating video codec with codec id: 28
18:17:43 T:4992 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:17:43 T:4992 NOTICE: Creating video thread
18:17:43 T:4992 NOTICE: Opening audio stream: 1 source: 256
18:17:43 T:4992 NOTICE: Finding audio codec for: 86019
18:17:43 T:4992 NOTICE: Creating audio thread
18:17:43 T:1248 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
18:17:43 T:1248 NOTICE: running thread: video_thread
18:17:43 T:4644 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
18:17:43 T:4644 NOTICE: running thread: CDVDPlayerAudio::Process()
18:17:43 T:4644 NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
18:17:43 T:1248 NOTICE: fps: 25.000000, pwidth: 720, pheight: 404, dwidth: 717, dheight: 404
18:17:43 T:1248 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
18:17:43 T:1248 NOTICE: D3D: rendering method forced to DXVA2 processor
18:17:48 T:4644 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:18:56 T:4348 WARNING: Previous line repeats 76 times.
18:18:56 T:4348 NOTICE: ES: Client from 127.0.0.1 timed out
18:25:35 T:4644 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:25:36 T:1248 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:26:35 T:4644 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:26:35 T:1248 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:26:35 T:4992 NOTICE: CDVDPlayer::OnExit()
18:26:35 T:4992 NOTICE: DVDPlayer: eof, waiting for queues to empty
18:26:35 T:4992 NOTICE: DVDPlayer: closing audio stream
18:26:35 T:4992 NOTICE: Closing audio stream
18:26:35 T:4992 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
18:26:35 T:4992 NOTICE: Waiting for audio thread to exit
18:26:35 T:4644 NOTICE: thread end: CDVDPlayerAudio::OnExit()
18:26:35 T:4992 NOTICE: Closing audio device
18:26:35 T:4992 NOTICE: Deleting audio codec
18:26:35 T:4992 NOTICE: DVDPlayer: closing video stream
18:26:35 T:4992 NOTICE: Closing video stream
18:26:35 T:4992 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
18:26:35 T:4992 NOTICE: waiting for video thread to exit
18:26:35 T:1248 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
18:26:35 T:1248 NOTICE: thread end: video_thread
18:26:35 T:4992 NOTICE: deleting video codec
18:26:35 T:4992 NOTICE: CDVDPlayer::OnExit() deleting demuxer
18:26:35 T:4992 NOTICE: CDVDPlayer::OnExit() deleting input stream
18:26:36 T:1688 NOTICE: Thread Background Loader start, auto delete: false
18:26:36 T:2720 NOTICE: Thread Jobworker start, auto delete: true
18:26:36 T:3784 NOTICE: Previous line repeats 1 times.
18:26:36 T:3784 NOTICE: CDVDPlayer::CloseFile()
18:26:36 T:3784 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:26:36 T:3784 NOTICE: DVDPlayer: waiting for threads to exit
18:26:36 T:3784 NOTICE: DVDPlayer: finished waiting
18:29:51 T:4724 NOTICE: Thread Jobworker start, auto delete: true
18:33:21 T:3784 NOTICE: Previous line repeats 2 times.
18:33:21 T:3784 NOTICE: Log level changed to 2
18:33:21 T:3784 NOTICE: Enabled debug logging due to GUI setting. Level 2.
18:33:21 T:3784 DEBUG: ------ Window Init () ------
18:33:30 T:3784 DEBUG: CApplication::OnKey: menu (d8) pressed, action is PreviousMenu
18:33:30 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:33:30 T:3784 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
18:33:30 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:33:30 T:3784 DEBUG: ------ Window Init (Settings.xml) ------
18:33:30 T:5084 NOTICE: Thread Jobworker start, auto delete: true
18:33:35 T:3784 DEBUG: CApplication::OnKey: menu (d8) pressed, action is PreviousMenu
18:33:35 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:33:35 T:3784 DEBUG: ------ Window Deinit (Settings.xml) ------
18:33:35 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:33:35 T:3784 DEBUG: ------ Window Init (Home.xml) ------
18:33:40 T:3784 DEBUG: CApplication::OnKey: 169 (a9) pressed, action is Left
18:33:49 T:3784 DEBUG: Previous line repeats 3 times.
18:33:49 T:3784 DEBUG: CApplication::OnKey: 167 (a7) pressed, action is Down
18:33:50 T:3784 DEBUG: CApplication::OnKey: 11 (0b) pressed, action is Select
18:33:50 T:3784 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(Videos,RecentlyAddedMovies,return)
18:33:50 T:3784 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(Videos,RecentlyAddedMovies,return)
18:33:50 T:3784 DEBUG: Activating window ID: 10025
18:33:50 T:3784 DEBUG: ------ Window Deinit (Home.xml) ------
18:33:50 T:3784 DEBUG: CApplication::ExecuteXBMCAction : Translating SetProperty(VideosDirectLink,True)
18:33:50 T:3784 DEBUG: CApplication::ExecuteXBMCAction : To SetProperty(VideosDirectLink,True)
18:33:50 T:3784 DEBUG: ------ Window Init (MyVideoNav.xml) ------
18:33:50 T:3784 DEBUG: CGUIMediaWindow::GetDirectory (videodb://4/)
18:33:50 T:3784 DEBUG: ParentPath = [videodb://4/]
18:33:50 T:3784 DEBUG: CVideoDatabase::RunQuery took 196 ms for 25 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 25
18:33:50 T:3628 NOTICE: Thread Background Loader start, auto delete: false
18:33:50 T:3628 DEBUG: Thread Background Loader 3628 terminating
18:33:53 T:3784 DEBUG: CApplication::OnKey: 11 (0b) pressed, action is Select
18:33:53 T:3784 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
18:33:54 T:3784 DEBUG: CApplication::OnKey: 11 (0b) pressed, action is Select
18:33:54 T:3784 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
18:33:55 T:3784 DEBUG: CGUIWindowVideoBase::OnPlayMedia S:\Over the Hedge (2006)\Over the Hedge (2006).mkv
18:33:55 T:3784 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
18:33:55 T:3784 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
18:33:55 T:3784 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
18:33:55 T:3784 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers(S:\Over the Hedge (2006)\Over the Hedge (2006).mkv)
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
18:33:55 T:3784 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
18:33:55 T:3784 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
18:33:55 T:3784 NOTICE: DVDPlayer: Opening: S:\Over the Hedge (2006)\Over the Hedge (2006).mkv
18:33:55 T:3784 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:33:55 T:3784 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
18:33:55 T:3784 DEBUG: DXVA - cheking samples array size using 842094158 render target
18:33:55 T:3784 DEBUG: DXVA - cheking samples array size using 842094169 render target
18:33:55 T:3624 NOTICE: Thread CDVDPlayer start, auto delete: false
18:33:55 T:3624 NOTICE: Creating InputStream
18:33:55 T:3624 DEBUG: CUtil::ScanForExternalSubtitles: Searching for subtitles...
18:33:55 T:3624 DEBUG: CUtil::ScanForExternalSubtitles: END (total time: 85 ms)
18:33:55 T:3624 NOTICE: Creating Demuxer
18:33:55 T:3624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
18:33:55 T:3624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
18:33:55 T:3784 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:33:55 T:3624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
18:33:55 T:3624 DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [matroska,webm]
18:33:55 T:3624 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
18:33:55 T:3624 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
18:33:55 T:3624 INFO: ffmpeg[E28]: Input #0, matroska,webm, from 'S:\Over the Hedge (2006)\Over the Hedge (2006).mkv':
18:33:55 T:3624 INFO: ffmpeg[E28]: Duration: 01:19:46.56, start: 0.000000, bitrate: 1461 kb/s
18:33:55 T:3624 INFO: ffmpeg[E28]: Stream #0:0(eng): Video: h264 (High), yuv420p, 720x404 [SAR 404:405 DAR 16:9], SAR 254:255 DAR 3048:1717, 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
18:33:55 T:3624 INFO: ffmpeg[E28]: Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), s16, 256 kb/s (default)
18:33:55 T:3624 NOTICE: Opening video stream: 0 source: 256
18:33:55 T:3624 NOTICE: Creating video codec with codec id: 28
18:33:55 T:3624 DEBUG: CDVDFactoryCodec: compiled in hardware support: CrystalHD:yes DXVA:yes
18:33:55 T:3624 DEBUG: FactoryCodec - Video: - Opening
18:33:55 T:3624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swscale-2.dll)
18:33:55 T:3624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swresample-0.dll)
18:33:55 T:3624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avfilter-2.dll)
18:33:55 T:3624 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:33:55 T:3624 DEBUG: FactoryCodec - Video: ff-h264 - Opened
18:33:55 T:3624 NOTICE: Creating video thread
18:33:55 T:3624 NOTICE: Opening audio stream: 1 source: 256
18:33:55 T:3624 NOTICE: Finding audio codec for: 86019
18:33:55 T:3624 DEBUG: FactoryCodec - Audio: passthrough - Opening
18:33:55 T:3624 DEBUG: FactoryCodec - Audio: passthrough - Opened
18:33:55 T:3624 DEBUG: CDVDPlayerAudio: Sample rate changed, checking for passthrough
18:33:55 T:3348 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
18:33:55 T:3348 NOTICE: running thread: video_thread
18:33:55 T:3348 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
18:33:55 T:3624 NOTICE: Creating audio thread
18:33:55 T:3624 DEBUG: CEdl::ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: S:\Over the Hedge (2006)\Over the Hedge (2006).mkv
18:33:55 T:3624 DEBUG: CDVDPlayer::Process - Start position set to last stopped position: 877000
18:33:55 T:3056 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
18:33:55 T:3056 NOTICE: running thread: CDVDPlayerAudio::Process()
18:33:55 T:3624 DEBUG: CDVDDemuxFFmpeg::SeekTime - seek ended up on time 878240
18:33:55 T:3624 DEBUG: CDVDPlayer::Process - starting demuxer from: 877000
18:33:55 T:3624 DEBUG: CDVDPlayer::SetCaching - caching state 3
18:33:56 T:3784 DEBUG: CGUIInfoManager::SetCurrentMovie(S:\Over the Hedge (2006)\Over the Hedge (2006).mkv)
18:33:56 T:3784 DEBUG: CVideoDatabase::GetMovieId (S:\Over the Hedge (2006)\Over the Hedge (2006).mkv), query = select idMovie from movie where idFile=3220
18:33:56 T:3784 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:33:56 T:3784 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:33:56 T:3348 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(878240000.000000, 1)
18:33:56 T:3056 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(878272000.000000, 0)
18:33:56 T:3056 INFO: CAEStreamInfo::SyncAC3 - AC3 stream detected (6 channels, 48000Hz)
18:33:56 T:3056 DEBUG: CDVDPlayerAudio: Sample rate changed, checking for passthrough
18:33:56 T:3056 DEBUG: FactoryCodec - Audio: passthrough - Opening
18:33:56 T:3056 DEBUG: FactoryCodec - Audio: passthrough - Opened
18:33:56 T:3056 NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
18:33:56 T:3056 INFO: CSoftAE::MakeStream - AE_FMT_AC3, 48000, RAW,RAW
18:33:56 T:3348 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
18:33:56 T:3348 DEBUG: DXVA - supports 'MPEG2 IDCT'
18:33:56 T:3348 DEBUG: DXVA - supports 'MPEG1/2 VLD'
18:33:56 T:3348 DEBUG: DXVA - supports 'MPEG2 VLD'
18:33:56 T:3348 DEBUG: DXVA - supports 6F3EC719-3735-42cc-8063-65cc3cb36616
18:33:56 T:3348 DEBUG: DXVA - supports 'VC-1 VLD 2010'
18:33:56 T:3348 DEBUG: DXVA - supports 'VC-1 VLD'
18:33:56 T:3348 DEBUG: DXVA - supports 'VC-1 IDCT'
18:33:56 T:3348 DEBUG: DXVA - supports 'Windows Media Video 9 IDCT'
18:33:56 T:3348 DEBUG: DXVA - supports 32FCFE3F-de46-4a49-861b-ac71110649d5
18:33:56 T:3348 DEBUG: DXVA - supports D79BE8DA-0cf1-4c81-b82a-69a4e236f43d
18:33:56 T:3348 DEBUG: DXVA - supports F9AACCBB-c2b6-4cfc-8779-5707b1760552
18:33:56 T:3348 DEBUG: DXVA - supports 'H.264 VLD, no FGT'
18:33:56 T:3348 DEBUG: DXVA - supports EFD64D74-c9e8-41d7-a5e9-e9b0e39fa319
18:33:56 T:3348 DEBUG: DXVA - supports ED418A9F-010d-4eda-9ae3-9a65358d8d2e
18:33:56 T:3348 DEBUG: DXVA - supports 9947EC6F-689b-11dc-a320-0019dbbc4184
18:33:56 T:3348 DEBUG: DXVA - supports B194EB52-19a0-41f0-b754-cc244ac1cb20
18:33:56 T:3348 DEBUG: DXVA - trying 'H.264 VLD, no FGT'
18:33:56 T:3348 DEBUG: DXVA - source requires 6 references
18:33:56 T:3348 DEBUG: DXVA - config 0: bitstream type 1
18:33:56 T:3348 DEBUG: DXVA - config 1: bitstream type 2
18:33:56 T:3348 DEBUG: DXVA - allocating 11 surfaces
18:33:56 T:1552 DEBUG: CSoftAE::Run - Sink restart flagged
18:33:56 T:1552 INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
18:33:56 T:1552 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
18:33:56 T:1552 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
18:33:56 T:3348 INFO: ffmpeg[D14]: [h264] Cannot parallelize deblocking type 1, decoding such frames in sequential order
18:33:56 T:3348 NOTICE: fps: 25.000000, pwidth: 720, pheight: 404, dwidth: 717, dheight: 404
18:33:56 T:3348 DEBUG: CDVDPlayerVideo::OutputPicture - change configuration. 720x404. framerate: 25.00. format: DXVA
18:33:56 T:3348 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
18:33:56 T:3348 NOTICE: D3D: rendering method forced to DXVA2 processor
18:33:56 T:3348 DEBUG: DXVA - processor found Spatial-temporal device
18:33:56 T:3348 DEBUG: DXVA - processor found Unknown device (nVidia)
18:33:56 T:3348 DEBUG: DXVA - processor found Progressive Device
18:33:56 T:3348 DEBUG: DXVA - processor found Bob Device
18:33:56 T:3348 DEBUG: DXVA - processor selected Progressive Device
18:33:56 T:3348 DEBUG: DXVA - processor requires 0 past frames and 0 future frames
18:33:56 T:3348 DEBUG: CWinRenderer::SelectRenderMethod: Selected render method 3: DXVA
18:33:56 T:1552 INFO: CAESinkWASAPI::InitializeExclusive: Format is Supported - will attempt to Initialize
18:33:56 T:3784 DEBUG: Activating window ID: 12005
18:33:56 T:3784 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
18:33:56 T:3784 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
18:33:56 T:1552 INFO: CAESinkWASAPI::InitializeExclusive: WASAPI Exclusive Mode Sink Initialized using: AE_FMT_S16NE, 48000, 2
18:33:56 T:1552 DEBUG: CSoftAE::InternalOpenSink - WASAPI Initialized:
18:33:56 T:1552 DEBUG: Output Device : HDMI - M470NV-1 (NVIDIA High Definition Audio)
18:33:56 T:1552 DEBUG: Sample Rate : 48000
18:33:56 T:1552 DEBUG: Sample Format : AE_FMT_S16NE
18:33:56 T:1552 DEBUG: Channel Count : 2
18:33:56 T:1552 DEBUG: Channel Layout: RAW,RAW
18:33:56 T:1552 DEBUG: Frames : 2400
18:33:56 T:1552 DEBUG: Frame Samples : 4800
18:33:56 T:1552 DEBUG: Frame Size : 4
18:33:56 T:1552 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 9600
18:33:56 T:3056 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
18:33:56 T:3624 DEBUG: CDVDPlayer::HandleMessages - player started 1
18:33:56 T:3784 DEBUG: created video buffer 0
18:33:56 T:3784 DEBUG: created video buffer 1
18:33:56 T:3784 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
18:33:56 T:3624 DEBUG: CDVDPlayer::HandleMessages - player started 2
18:33:56 T:3624 DEBUG: CDVDPlayer::SetCaching - caching state 0
18:33:56 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:878240248.052361, should be:878300395.588988, error:60147.536626
18:33:56 T:1552 DEBUG: CAESinkWASAPI::IsCompatible: Formats compatible - reusing existing sink
18:33:56 T:1552 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_AC3, RAW,RAW, 48000hz
18:33:56 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:878433700.068414, should be:878304000.000000, error:-129700.068414
18:33:58 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:880304135.716005, should be:880267856.327173, error:-36279.388831
18:34:01 T:3348 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
18:34:20 T:5084 DEBUG: Thread Jobworker 5084 terminating (autodelete)
18:34:55 T:4348 NOTICE: ES: Client from 127.0.0.1 timed out
18:35:22 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:964432370.925767, should be:964422149.269711, error:-10221.656057
18:36:22 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:1024432004.646630, should be:1024421819.701604, error:-10184.945026
18:37:22 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:1084431668.235700, should be:1084421530.123164, error:-10138.112536
18:38:21 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:1142782308.311892, should be:1142772195.998155, error:-10112.313737
18:39:19 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:1200782083.308252, should be:1200772043.245104, error:-10040.063148
18:39:35 T:3056 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:39:35 T:3348 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:39:36 T:1552 DEBUG: CSoftAEStream::GetFrame - Underrun
18:39:36 T:3056 DEBUG: CSoftAEStream::Flush
18:39:36 T:3348 INFO: CDVDPlayerVideo - Stillframe detected, switching to forced 25.000000 fps
18:39:36 T:3348 DEBUG: CPullupCorrection: pattern lost on diff 200000.000000
18:39:41 T:3348 DEBUG: Previous line repeats 26 times.
18:39:41 T:3348 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
18:39:41 T:3056 DEBUG: CSoftAEStream::Flush
18:40:57 T:3624 DEBUG: Previous line repeats 419 times.
18:40:57 T:3624 ERROR: ffmpeg[E28]: [matroska,webm] Read error
18:40:57 T:3624 DEBUG: CDVDPlayer::SetCaching - caching state 1
18:40:57 T:3624 DEBUG: CDVDPlayer::HandleMessages - player started 1
18:40:57 T:3624 DEBUG: CDVDPlayer::SetCaching - caching state 0
18:40:57 T:3056 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:1298990495.261513, should be:1217802003.421412, error:-81188491.840101
18:40:57 T:3348 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
18:40:57 T:3348 DEBUG: CPullupCorrection: pattern lost on diff -81080000.000000
18:40:57 T:1552 DEBUG: CSoftAE::Run - Sink restart flagged
18:40:57 T:1552 INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
18:40:57 T:1552 DEBUG: CAESinkWASAPI::IsCompatible: Formats compatible - reusing existing sink
18:40:57 T:1552 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_AC3, RAW,RAW, 48000hz
18:40:57 T:1552 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 9600
18:40:57 T:3624 DEBUG: CDVDPlayer::HandleMessages - player started 2
18:40:57 T:3056 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_EOF
18:40:57 T:3056 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:40:58 T:1552 DEBUG: CSoftAEStream::GetFrame - Underrun
18:40:58 T:3624 NOTICE: CDVDPlayer::OnExit()
18:40:58 T:3624 NOTICE: DVDPlayer: eof, waiting for queues to empty
18:40:58 T:3624 NOTICE: DVDPlayer: closing audio stream
18:40:58 T:3624 NOTICE: Closing audio stream
18:40:58 T:3624 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
18:40:58 T:3056 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
18:40:58 T:3624 NOTICE: Waiting for audio thread to exit
18:40:58 T:3056 DEBUG: CDVDPlayerAudio::Process - Abort received, exiting thread
18:40:58 T:3056 NOTICE: thread end: CDVDPlayerAudio::OnExit()
18:40:58 T:3056 DEBUG: Thread CDVDPlayerAudio 3056 terminating
18:40:58 T:3624 NOTICE: Closing audio device
18:40:58 T:3624 DEBUG: CSoftAEStream::~CSoftAEStream - Destructed
18:40:58 T:3624 NOTICE: Deleting audio codec
18:40:58 T:3624 NOTICE: DVDPlayer: closing video stream
18:40:58 T:3624 NOTICE: Closing video stream
18:40:58 T:3624 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
18:40:58 T:3348 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
18:40:58 T:3348 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:40:58 T:3348 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
18:40:58 T:3348 NOTICE: thread end: video_thread
18:40:58 T:3348 DEBUG: Thread CDVDPlayerVideo 3348 terminating
18:40:58 T:3624 NOTICE: waiting for video thread to exit
18:40:58 T:3624 NOTICE: deleting video codec
18:40:58 T:3624 NOTICE: CDVDPlayer::OnExit() deleting demuxer
18:40:58 T:3624 NOTICE: CDVDPlayer::OnExit() deleting input stream
18:40:58 T:3624 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
18:40:58 T:3624 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
18:40:58 T:3624 DEBUG: Thread CDVDPlayer 3624 terminating
18:40:58 T:1552 DEBUG: CSoftAE::Run - Sink restart flagged
18:40:58 T:1552 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
18:40:58 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:40:58 T:3784 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
18:40:58 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:40:58 T:3784 DEBUG: ------ Window Init (MyVideoNav.xml) ------
18:40:58 T:3784 DEBUG: CGUIMediaWindow::GetDirectory (videodb://4/)
18:40:58 T:3784 DEBUG: ParentPath = [videodb://4/]
18:40:58 T:1552 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 2097734
18:40:58 T:1552 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
18:40:58 T:1552 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
18:40:58 T:1552 DEBUG: Audio Device : M470NV-1 (NVIDIA High Definition Audio)
18:40:58 T:1552 DEBUG: Sample Rate : 44100
18:40:58 T:1552 DEBUG: Sample Format : AE_FMT_FLOAT
18:40:58 T:1552 DEBUG: Bits Per Sample : 32
18:40:58 T:1552 DEBUG: Valid Bits/Samp : 32
18:40:58 T:1552 DEBUG: Channel Count : 2
18:40:58 T:1552 DEBUG: Block Align : 8
18:40:58 T:1552 DEBUG: Avg. Bytes Sec : 352800
18:40:58 T:1552 DEBUG: Samples/Block : 32
18:40:58 T:1552 DEBUG: Format cBSize : 22
18:40:58 T:1552 DEBUG: Channel Layout : FL,FR
18:40:58 T:1552 DEBUG: Channel Mask : 3
18:40:58 T:1552 DEBUG: Frames : 441
18:40:58 T:1552 DEBUG: Frame Samples : 882
18:40:58 T:1552 DEBUG: Frame Size : 8
18:40:58 T:1552 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
18:40:58 T:1552 DEBUG: Output Device : HDMI - M470NV-1 (NVIDIA High Definition Audio)
18:40:58 T:1552 DEBUG: Channel Layout: FL,FR
18:40:58 T:1552 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
18:40:58 T:1552 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
18:40:58 T:1552 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
18:40:58 T:3784 DEBUG: CVideoDatabase::RunQuery took 235 ms for 25 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 25
18:40:58 T:1276 NOTICE: Thread Background Loader start, auto delete: false
18:40:58 T:1276 DEBUG: Thread Background Loader 1276 terminating
18:40:59 T:3784 NOTICE: CDVDPlayer::CloseFile()
18:40:59 T:3784 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:40:59 T:3784 NOTICE: DVDPlayer: waiting for threads to exit
18:40:59 T:3784 NOTICE: DVDPlayer: finished waiting
18:40:59 T:1140 NOTICE: Thread Jobworker start, auto delete: true
18:40:59 T:1140 DEBUG: CSaveFileStateJob::DoWork - Saving file state for video item S:\Over the Hedge (2006)\Over the Hedge (2006).mkv
18:40:59 T:1140 DEBUG: CAnnouncementManager - Announcement: OnUpdate from xbmc
18:40:59 T:1140 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnUpdate
18:41:08 T:1552 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
18:41:08 T:1552 DEBUG: Suspended the Sink
18:41:09 T:3784 DEBUG: CApplication::OnKey: 11 (0b) pressed, action is Select
18:41:09 T:1552 DEBUG: Resumed the Sink
18:41:09 T:1552 DEBUG: CSoftAE::Run - Sink restart flagged
18:41:09 T:1552 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
18:41:09 T:3784 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
18:41:09 T:1552 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 2097734
18:41:09 T:1552 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
18:41:09 T:1552 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
18:41:09 T:1552 DEBUG: Audio Device : M470NV-1 (NVIDIA High Definition Audio)
18:41:09 T:1552 DEBUG: Sample Rate : 44100
18:41:09 T:1552 DEBUG: Sample Format : AE_FMT_FLOAT
18:41:09 T:1552 DEBUG: Bits Per Sample : 32
18:41:09 T:1552 DEBUG: Valid Bits/Samp : 32
18:41:09 T:1552 DEBUG: Channel Count : 2
18:41:09 T:1552 DEBUG: Block Align : 8
18:41:09 T:1552 DEBUG: Avg. Bytes Sec : 352800
18:41:09 T:1552 DEBUG: Samples/Block : 32
18:41:09 T:1552 DEBUG: Format cBSize : 22
18:41:09 T:1552 DEBUG: Channel Layout : FL,FR
18:41:09 T:1552 DEBUG: Channel Mask : 3
18:41:09 T:1552 DEBUG: Frames : 441
18:41:09 T:1552 DEBUG: Frame Samples : 882
18:41:09 T:1552 DEBUG: Frame Size : 8
18:41:09 T:1552 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
18:41:09 T:1552 DEBUG: Output Device : HDMI - M470NV-1 (NVIDIA High Definition Audio)
18:41:09 T:1552 DEBUG: Channel Layout: FL,FR
18:41:09 T:1552 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
18:41:09 T:1552 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
18:41:09 T:1552 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
18:41:10 T:3784 DEBUG: CApplication::OnKey: menu (d8) pressed, action is Back
18:41:10 T:3784 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
18:41:11 T:3784 DEBUG: CApplication::OnKey: menu (d8) pressed, action is Back
18:41:11 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:41:12 T:3784 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
18:41:12 T:3784 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:41:12 T:3784 DEBUG: ------ Window Init (Home.xml) ------
18:41:13 T:3784 DEBUG: CApplication::OnKey: 167 (a7) pressed, action is Down
18:41:14 T:3784 DEBUG: Previous line repeats 1 times.
18:41:14 T:3784 DEBUG: CApplication::OnKey: 11 (0b) pressed, action is Select
18:41:14 T:3784 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(ShutdownMenu)
18:41:14 T:3784 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(ShutdownMenu)
18:41:14 T:3784 DEBUG: Activating window ID: 10111
18:41:14 T:3784 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
18:41:14 T:3784 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
18:41:14 T:3784 DEBUG: CApplication::ExecuteXBMCAction : Translating down
18:41:14 T:3784 DEBUG: CApplication::ExecuteXBMCAction : To down
18:41:14 T:3784 DEBUG: CApplication::ExecuteXBMCAction : Translating XBMC.Quit()
18:41:14 T:3784 DEBUG: CApplication::ExecuteXBMCAction : To XBMC.Quit()
18:41:14 T:3784 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
18:41:14 T:3784 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
18:41:14 T:3784 NOTICE: Storing total System Uptime
18:41:14 T:1140 DEBUG: Thread Jobworker 1140 terminating (autodelete)
18:41:14 T:3784 NOTICE: Saving settings
18:41:14 T:3784 NOTICE: stop all
18:41:14 T:3784 INFO: stopping PVRManager
18:41:14 T:3784 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
18:41:14 T:3784 NOTICE: ES: Stopping event server
18:41:14 T:3784 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
18:41:14 T:3784 NOTICE: stopping zeroconf publishing
18:41:14 T:4356 DEBUG: Thread CTCPServer 4356 terminating
18:41:15 T:4348 NOTICE: ES: UDP Event server stopped
18:41:15 T:4348 DEBUG: Thread CEventServer 4348 terminating
18:41:15 T:2552 DEBUG: Thread XBMC Peripherals 2552 terminating
18:41:15 T:1960 DEBUG: Thread XBMC Peripherals 1960 terminating
18:41:15 T:3784 NOTICE: stop sap announcement listener
18:41:15 T:3784 NOTICE: clean cached files!
18:41:15 T:3784 NOTICE: unload skin
18:41:15 T:3784 INFO: Unloading old skin ...
18:41:15 T:3784 DEBUG: ------ Window Deinit () ------
18:41:15 T:3784 DEBUG: ------ Window Deinit (Home.xml) ------
18:41:15 T:3784 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-nofocus.png
18:41:15 T:3784 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-focus.png
18:41:15 T:3784 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
18:41:15 T:3784 DEBUG: ADDON: Stopping service addons.
18:41:15 T:3784 INFO: Stopping script with id: 2
18:41:15 T:4444 NOTICE: StorageServer-2.5.4 Closed down
18:41:15 T:4444 INFO: Scriptresult: Success
18:41:15 T:3784 DEBUG: XBPyThread::stop - script termination took 299ms
18:41:15 T:3784 NOTICE: stop python
18:41:15 T:3784 DEBUG: waiting for python thread 2 (C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py​) to stop
18:41:15 T:3784 DEBUG: python thread 2 (C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py​) destructed
18:41:15 T:4444 DEBUG: Thread XBPyThread 4444 terminating
18:41:17 T:3784 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
18:41:17 T:1552 DEBUG: Thread CSoftAE 1552 terminating
18:41:17 T:3784 NOTICE: stopped
18:41:17 T:3784 NOTICE: destroy
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04EA2380 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 05371B00 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0538DC80 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04E5A908 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04EA2A88 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 05371D88 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04E5AB90 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0538DDA0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04E5ACB0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04EA2530 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 05371CB0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0538D9B0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04E5AF38 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04EA2650 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 053975D0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 052FF0D8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 05371758 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04E5AE60 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 053719E0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0538DB60 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04EA2770 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0540B0F8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:17 T:3784 NOTICE: closing down remote control service
18:41:17 T:3784 NOTICE: unload sections
18:41:17 T:3784 INFO: lastfm destroyed
18:41:17 T:3784 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
18:41:17 T:3784 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
18:41:17 T:3784 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
18:41:17 T:3784 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
18:41:17 T:3784 DEBUG: Previous line repeats 1 times.
18:41:17 T:3784 NOTICE: application stopped...
18:41:17 T:3784 DEBUG: PVRManager - destroyed
18:41:17 T:3784 DEBUG: SECTION:UnloadDll(special://xbmcbin/system/libcurl.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/cpluff.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/libcec.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/swscale-2.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/swresample-0.dll)
18:41:17 T:3784 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/players/dvdplayer/avfilter-2.dll)
The buffering seemed to be caused by my router. I reset it and I have not had any buffering since. I guess I didn't leave it unplugged long enough when I tried that before.
Resolved.
Please don't load up the forums with log files.... use http://xbmclogs.com/ and link nack to a message.
Reference URL's
