Updated Frodo Branch
- updated OpenElec build (3.2.4)
- updated firmware and kernel
- sync with
https://github.com/popcornmix/xbmc/commi..._backports
- [rbp/omxplayer] Do we need discontinuity handling?
- [rbp/omxplayer] Avoid marking non-monotonic timestamps as unknown
- [rbp/omxplayer] When opening a stream don't try to update gui so often
- [rbp/omxplayer] Defer demuxer pause until buffers full
- [rbp/omxplayer] Use display time for EDL cut start time
- [rbp/omxplayer] Avoid setting TIME_UNKNOWN on packet with STARTTIME set
- [rbp/omxplayer] Fix for all subs being rendered at start of file
http://netlir.dk/rbej/builds/
http://lysin.me/rbej
(2013-11-28, 12:17)MilhouseVH Wrote: [ -> ] (2013-11-28, 12:02)Koloss Wrote: [ -> ]@MilhouseVH: Can i post your Build in a german XBMC Forum?
I say this is your build!
Sure, though I will take down the file when it is updated by a newer version so please point them to this thread for latest version etc.
@rbej: i post your build in the same forum, it's ok?
@MilhouseVH: Your last build is very good, i think it is a little bit faster as the old build from you.
DTS, AC3 Passthrought is ok, subtitle in file is ok, Temp is lower.
rbej, thanks for your build.
Should I copy advancedsetting.xml to my Pi?
Thanks.[/i]
(2013-11-28, 02:24)MilhouseVH Wrote: [ -> ]New OpenELEC Gotham build on dropbox.
rpi512:~ # vcgencmd version
Nov 27 2013 22:47:13
Copyright (c) 2012 Broadcom
version 95b18c7513b1cdd8ab76f541338f749285898fb7 (tainted) (release)
rpi512:~ # uname -a
Linux rpi512 3.12.1 #1 PREEMPT Wed Nov 27 23:09:45 GMT 2013 armv6l GNU/Linux
rpi512:~ # lsb_release
OpenELEC_Gotham (unofficial) - Version: devel-20131127234643-r16442
Based on tip of XBMC master (81a9c0c) and OpenELEC master (d1125a0) with the following modifications:- Includes latest firmware (7400b45) from master - initial testing confirms it's chirp-free!
- Includes these newclock3 commits (except for 09445f5 which I've replaced with a static spinner)
- Includes fix for consistent webserver/GUI artwork caching (PR:3671)
- Excludes the fernetmenta patch as this conflicts with the newclock3 ffmpeg (ad5987e) patch
This build includes even more newclock3 performance improvements, and also the EDL fix for anyone that is able to test that.
Many thanks to popcornmix for squashing these bugs with such dedication, and Ben for eking out even more performance!
Any chance of getting your builds supported with the devbuild update addon:
http://openelec.tv/forum/128-addons/49855
Thanks in advance
I will update mine.
allan87 Wrote: (2013-11-28, 18:37)evanspae Wrote: [ -> ]...alas I am now getting a drift of lipsync of approx 500ms over a 2hr period?
I did not notice a drift (a gradually shifting loss of sync), but did notice that audio was a fraction of a second off in a 1 hr MythTV recording, played back with the myth plugin. I'll check an earlier, previously watched recording that was OK, and post if further viewing reveals anything different.
Well, I watched
- a show that was .5 seconds off at the beginning, and became synched at some point in the middle;
- another show that was in perfect sync throughout.
There may be an intermittent sync issue but I don't see drifting.
(2013-11-28, 23:36)goRt Wrote: [ -> ] (2013-11-28, 02:24)MilhouseVH Wrote: [ -> ]New OpenELEC Gotham build on dropbox.
rpi512:~ # uname -a
Thanks in advance
ethernet not working for me on a new install with this build posted.
(2013-11-29, 03:35)jvilla Wrote: [ -> ] (2013-11-28, 23:36)goRt Wrote: [ -> ] (2013-11-28, 02:24)MilhouseVH Wrote: [ -> ]New OpenELEC Gotham build on dropbox.
rpi512:~ # uname -a
Thanks in advance
Same here. Actually when I get to the network screen, it locks up solid.
512meg pi plugged into gigabit ethernet
Possibly a variation of the existing issue with the network setup wizard, try installing a 3.2.4 release build, configure your network then upgrade to the development Gotham build.
rpi512:~ # uname -a
Thanks in advance
@MilhouseVH If you could put your builds into the same Dropbox folder and share the url to the folder then I can add it to the add-on. I've found your builds to be a big improvement over the latest OpenELEC release so it would be great if you could do that.
popcornmix Thanks for your work in helping to make the RPi an amazing media centre device. The recent improvements have been superb, especially when compared to a year ago.
I tried the 10/9 rbej build and it went through fine. However, I could not install any addons. I was able to install fanart, but confluence modified stopped at 55% and never went any further. Weather underground also stopped at 55% and would not install further. A couple other ones would not even start the install portion. Doubt it is related but worth mentioning.
(2013-11-29, 06:55)Leopold Wrote: [ -> ]@MilhouseVH If you could put your builds into the same Dropbox folder and share the url to the folder then I can add it to the add-on. I've found your builds to be a big improvement over the latest OpenELEC release so it would be great if you could do that.
Leopold - OK I'm looking into it, will let you know shortly.
It would be nice if we could have a shared folder with the latest builds available to download.
