Tried updating to 3.2.1, via dropping KERNAL and SYSTEM files in update folder. After reboot it couldnt find the storage partition. I have it on USB, I checked cmdline.txt and it was still correct.
I thought update might not work if storage is on USB. Got image of 3.2.1 'thestateofme'. First time it seemed corrupted, so I re-downloaded and tried again. Keeps hanging on boot and complaining it cant find /sda1 storage. It did eventually boot up once, but it took about 3 minutes.
I thought maybe the storage partition had been damaged, went back to 3.2 and its completely fine.
Cheers Milhouse, gave it a shot, still fails to mount storage. I'll just wait for 3.2.2.
Following this on github about CEC and LG tvs.
https://github.com/Pulse-Eight/libcec/is...t-25330279
LG tvs have new firmware version 4 which is not compatible with libCEC in 3.2. Any chance updating libCEC with future releases?
(2013-09-30, 07:15)Wanderlei Wrote: [ -> ]Tried updating to 3.2.1, via dropping KERNAL and SYSTEM files in update folder. After reboot it couldnt find the storage partition. I have it on USB, I checked cmdline.txt and it was still correct.
Apparently there's a problem with the firmware when you use USB Storage partition. Tested it yesterday. Results:
Create new card under Ubuntu with 3.2.1 - RPi doesn't boot. Stops at OpenELEC logo.
Create new card under Ubuntu with 3.2.0 and manual copying 3.2.1 files - RPi doesn't boot. Stops at OpenELEC logo.
OpenELEC 3.2.0 internal update to 3.2.1 - Stops at OpenELEC logo, chews something for a bit, takes a few minutes to fully boot (3.2.0 can boot in under 30s). Very unstable and sometimes spits out "canĀ“t find /dev/sda1 bla bla bla..."
Also tried disk=LABEL=Storage and disk=UUID=uuid_value_here. Same problem.
Using only the SD card seems to work a lot better, aldo a lot slower than 3.2.0. Takes well over a minute to boot.
If you have usb problems on 3.2.1, can you report:
(2013-09-30, 12:57)popcornmix Wrote: [ -> ]If you have usb problems on 3.2.1, can you report:
Sorry, I try but it keeps getting stuck at the logo and I cant connect to it. (what hudo explained is exactly what I experience too)
Can't test now. I'm at work. I'll test later following the procedure described above (OE internal update form 3.2.0 to 3.2.1). Seems to be the only one working, sort of.
(2013-09-21, 21:22)javaboyuk Wrote: [ -> ]Alas with the
hdmi_force_open=1
With 3.1.6 and still with 3.2 on my Raspberry PI, I find if I "jump" to the next song or skip forward in the song my raspberry will loop playing the "current" 1/4 second of music and you have to reboot the PI to stop this, unplugging and plugging th HDMI does not fix it, and nor does trying to stop, play another track etc work. However I can still reboot the PI.
(Note I am controlling the PI vi the XBMC remote controller on my iPhone over wifi.)
So looks like a firmware/driver issue
Any suggestions who I can talk to about this, happy to help.
I spent some time stepping through the code and believe I have fixed the issue.
I've also tried to do sane things when switching between PCM and passthrough audio.
Can you follow the update procedure in previous post, and report if the behaviour is better.
(2013-09-30, 16:46)popcornmix Wrote: [ -> ]People with USB issues on 3.2.1 can you try updating firmware manually. Download:
https://github.com/Hexxeh/rpi-firmware/r...tart_x.elf
https://github.com/Hexxeh/rpi-firmware/r...ixup_x.dat
and replace start.elf and fixup.dat on the boot partition of sdcard. Let me know if it fixes it.
I've been using the last rbej frodo build on usb, and the booting has been very flaky. I don't think it's re-booted at all, booting from powered off has been mixed. Swapped those out and it's back to booting reliably.
I guess that means it's the same problem, as booting 3.2 has never been an issue.
The video's great btw.
Why are there no newer Gotham builds lately?
Maybe a stupid question....I am also testing this build and have the replace files.....but do I have to rename them to start.elf and fixup.dat?
