Full Version: OpenELEC Testbuilds for RaspberryPi Part 2
Mh.. in this 02.10. build of gotham, video playback isn't smooth when enabling "automatically adjust refresh rate"... it was butter smooth before. any1 else experiencing this?
(2013-10-06, 08:57)FattyMcDirty Wrote: [ -> ]Mh.. in this 02.10. build of gotham, video playback isn't smooth when enabling "automatically adjust refresh rate"... it was butter smooth before. any1 else experiencing this?
I've been using the 2.10 rbej build and video is smooth.
Is it happening for all videos, or just one?
Does the TV switch to the right mode (e.g. 1080p24 ?)
yes. it does switch to 1080p24 correctly... it's happening for all videos. it's kinda stuttering..
(2013-10-06, 12:05)FattyMcDirty Wrote: [ -> ]yes. it does switch to 1080p24 correctly... it's happening for all videos. it's kinda stuttering..
Does the previous rbej build behave better?
(2013-10-05, 16:50)Cassiel Wrote: [ -> ]Currently using TVHeadend on my NAS and H.264 Channels do work… I first thought it was a bandwidth problem of the USB WiFi adapter, but HD channels work great. Maybe deinterlacing is breaking the SD playback?
Well I've got deinterlace enabled and it's working but I've noticed it's using around 59-66% CPU, whereas before Live TV was around 35-40%. Opening the EPG, it only increases to around 69-71%, whereas normally there's a large difference between media playback and the GUI, so something's not right. Sometimes it just locks up when I open the EPG with TV playing, so it's obviously overloading the CPU at times.
If I disable deinterlace, it drops back down to around 40% with Live TV.
yes, the one from 11.09. was working fluid
the pixel ratio settings wont save. every time I reboot then I need to reconfigure aigan.
Actually it's not just Recorded TV, if I try and step forward with any video it just freezes on a black screen until I stop it and restart.
Recorded TV is local, on the USB, whilst this video file was over NFS.
http://xbmclogs.com/show.php?id=66694
(2013-10-06, 16:33)doveman2 Wrote: [ -> ]Actually it's not just Recorded TV, if I try and step forward with any video it just freezes on a black screen until I stop it and restart.
Quote:15:05:53 T:3061969936 ERROR: Keymapping error: no such action 'bigsteoforward' defined
Are you sure there's not a typo in your local keymap configuration file?
I actually cant install any addons anymore. They have all been marked as broken. when i select one, in the bottom it says "dependencies not met" or something like that. Am I missing something? Already deleted addon folder and database, didn't solve anything
(2013-10-06, 19:51)mikeb93 Wrote: [ -> ]I actually cant install any addons anymore. They have all been marked as broken. when i select one, in the bottom it says "dependencies not met" or something like that. Am I missing something? Already deleted addon folder and database, didn't solve anything
I've got the same thing especially with all the skins. Is this a gotham wide thing or just an openelec thing?
Popcornmix.
I have compile error with last updated newclock3.
Quote:make[2]: Entering directory `/home/rbej/OpenELEC.tv/build.OpenELEC_Gotham-RPi.arm-devel/xbmc-822e137/xbmc/main'
CPP xbmc/main/main.o
CPP xbmc/guilib/FrameBufferObject.o
CPP xbmc/utils/PerformanceStats.o
make -C xbmc/cores/DllLoader/exports wrapper.def
make[2]: Entering directory `/home/rbej/OpenELEC.tv/build.OpenELEC_Gotham-RPi.arm-devel/xbmc-822e137/xbmc/cores/DllLoader/exports'
make[2]: `wrapper.def' is up to date.
make[2]: Leaving directory `/home/rbej/OpenELEC.tv/build.OpenELEC_Gotham-RPi.arm-devel/xbmc-822e137/xbmc/cores/DllLoader/exports'
make -C lib
make[2]: Entering directory `/home/rbej/OpenELEC.tv/build.OpenELEC_Gotham-RPi.arm-devel/xbmc-822e137/lib'
make -C ffmpeg
CPP xbmc/guilib/GraphicContext.o
cp: cannot stat 'main.d': No such file or directory
make[2]: *** [main.o] Error 1
make[2]: Leaving directory `/home/rbej/OpenELEC.tv/build.OpenELEC_Gotham-RPi.arm-devel/xbmc-822e137/xbmc/main'
make[1]: *** [xbmc/main/main.a] Error 2
make[1]: *** Waiting for unfinished jobs....
music playback is broken on latest frodo build, plays the first song in an album then just stops when about to play the second
(2013-10-07, 08:48)rbej Wrote: [ -> ]Popcornmix.
That's an OpenELEC makefiles problem.
http://openelec.tv/forum/110-update-open...host-cores
It's not related to newclock3. Just try building again.
(2013-10-07, 10:25)stuCONNERS Wrote: [ -> ]music playback is broken on latest frodo build, plays the first song in an album then just stops when about to play the second
same with Gotham build ... first song plays and then xbmc crashes ... I try to upload some logs later
