Full Version: Manual Search In Subtitles not working in February Releases (Gotham)
I made this test with this 2 Windows nightlies:
- XBMCSetup-20140130-e55212c-master
- XBMCSetup-20140204-4e698ae-master
Always made fresh install, and then installed the OpenSubtitles service, and youtube addon. No changes were made after those installs.
The log of (XBMCSetup-20140130-e55212c-master):
http://xbmclogs.com/show.php?id=125205
The log of (XBMCSetup-20140204-4e698ae-master):
http://xbmclogs.com/show.php?id=125207
In both versions, I opened the same video from youtube, and tried to make a manual search on OpenSubtitles, on the version of 20140130 it worked (opens the input for the search), in the version of 20140204 nothing happens.
In one log the manualsearch is called, in the other not...
With this is easy to understand what can be wrong?
This also happens in latest release of OpenElec (Millhouse), so I think is a XBMC main core problem.
For foreign users the manual search is very usefull when the video doesn't have the correct name.
i'll check once I get home... feel free to remind me if I forget Smile
don't post snippets on the forum
(2014-02-05, 13:39)Martijn Wrote: [ -> ]don't post snippets on the forum
Sorry, will not happen again Smile
(2014-02-05, 17:54)amet Wrote: [ -> ]https://github.com/xbmc/xbmc/pull/4157
Lets see when fix is included to be used in nightlies Smile
maybe not in that form but something to that extend will be added
(2014-02-05, 18:06)amet Wrote: [ -> ]maybe not in that form but something to that extend will be added
Didn't understood, if the pull isn't committed will not appear in the nightlies, after the commit, as becomes available in master branch?
Or in other words, when will be expected to the manual search be used again? Only in the official release?
if this pull isn't committed some other solution will be, relax and wait patiently
(2014-02-05, 18:30)amet Wrote: [ -> ]if this pull isn't committed some other solution will be, relax and wait patiently
Ok, no problem, I didn't understood that you were referring to the case of the pull not being committed.
Let's see how it goes Smile
Well, already forked your OpenSubtitles and managed to always force manual search Smile
For me while they don't apply your fix I can search anyway!
Let's see if the best solution is applied and I don't have to use my forced way.
all fix on the last night thanks amet
Already tested. This thread can be closed, problem fixed.
