2014-03-04, 16:37
2014-03-04, 16:47
That is already available and it will auto update when Gotham is installed
2014-03-04, 17:59
Thank you.....
(2014-03-04, 16:47)Martijn Wrote: [ -> ]That is already available and it will auto update when Gotham is installed
2014-03-15, 13:20
Thanks, I have updated to Gotham Beta 1. I am a bit lost where the "update library" and "clean library" function went. Can you please share with me what I am missing.
2014-03-15, 18:14
(2014-03-15, 13:20)steve1977 Wrote: [ -> ]Thanks, I have updated to Gotham Beta 1. I am a bit lost where the "update library" and "clean library" function went. Can you please share with me what I am missing.
update library is now on the side menu.
clean library didn't move, but you need to set the settings level to advanced in order to see it.
2014-04-06, 21:01
I installed Gotham Beta 3 and T! updated. But I did notice that all of the features of the NextGen PVR add on are not supported (http://forums.gbpvr.com/showthread.php?5...tham-addon)
Are there any plans in the works to fully support these features?
Thanks.........
Thanks.........
2014-04-06, 21:55
nope, no plans...
2014-04-06, 22:56
