Full Version: Non English Characters
Hey everyone, I know that I am probably unusual in wanting this feature but my collection has a lot of both Anime and Studio Ghibli movies. The titles of which I like to see in Kanji eg もののけ姫 (Princess Mononoke) and the fonts included with Metropolis don't support the characters. The Airal font however does, to this end I have changed my Font.xml file to add Arial as an option (and still kept the formatting on the weather info in the bottom corner). If possible I would like to see this added to the distribution of Metropolis so I don't have to modify the xml file every time. In the mean time here are the changes I made. It is nearly all taken from the xml for confluence so that might be an issue but the weather section is pulled from the metropolis font.xml. If you want to make these changes yourself drop the following after the </fontset> at the end of the file.
edit: I don't know how to use git (yes I need to learn)
<fontset id="Arial for non English" unicode="true">
    <!-- Arial Font better for non English -->
         <font>
            <name>font10</name>
            <filename>arial.ttf</filename>
            <size>12</size>
        </font>
         <font>
            <name>font12</name>
            <size>15</size>
        </font>
         <font>
            <name>font13</name>
            <size>18</size>
        </font>
         <font>
            <name>font14</name>
            <size>20</size>
        </font>
         <font>
            <name>font16</name>
            <size>23</size>
        </font>
         <font>
            <name>font30</name>
            <size>28</size>
        </font>
         <font>
            <name>fontContextMenu</name>
            <size>16</size>
        </font>
    <!-- Title Fonts -->
         <font>
            <name>font10_title</name>
            <size>10</size>
            <style>bold</style>
        </font>
         <font>
            <name>font12_title</name>
            <size>15</size>
            <style>bold</style>
        </font>
         <font>
            <name>font13_title</name>
            <size>18</size>
            <style>bold</style>
        </font>
         <font>
            <name>font24_title</name>
            <size>22</size>
            <style>bold</style>
        </font>
         <font>
            <name>font28_title</name>
            <size>26</size>
            <style>bold</style>
        </font>
         <font>
            <name>font30_title</name>
            <size>28</size>
            <style>bold</style>
        </font>
         <font>
            <name>font35_title</name>
            <size>33</size>
            <style>bold</style>
        </font>
         <font>
            <name>font45caps_title</name>
            <size>43</size>
            <style>bold</style>
        </font>
         <font>
            <name>font_MainMenu</name>
            <size>35</size>
            <style>bold</style>
        </font>
        Font Weather and Time
         <font>
            <name>METF_WeatherHigh</name>
            <filename>MET_UbuntuRegular.ttf</filename>
            <size>62</size>
        </font>
        <font>
            <name>METF_WeatherLow</name>
            <size>50</size>
        </font>
        <font>
            <name>METF_Temp</name>
            <filename>MET_Myriad.ttf</filename>
            <size>28</size>
        </font>
        <font>
            <name>METF_Date</name>
            <filename>MET_FontinSansSmallCaps.ttf</filename>
            <size>30</size>
        </font>
        <font>
            <name>METF_OSDTime</name>
            <filename>MET_Bebas.ttf</filename>
            <size>22</size>
        </font>
        <font>
            <size>28</size>
        </font>
        <font>
            <size>30</size>
        </font>
        <font>
            <name>METF_Hours</name>
            <size>110</size>
        </font>
        <font>
            <name>METF_Minutes</name>
            <size>48</size>
        </font>
    </fontset>
Bumping this.
I tried this but it doesn't work for me. But then I have a bunch of Japanese MP3s. Does this fix not work for those? Do I need a copy of Arial in the Metropolis folder? I made sure to copy and paste after the last fontset but before /fonts.
I never tried it with music. My server is down currently, I moved house and haven't set it back up. Did you go into the settings and change your font selection? Also a heads up when they update the theme it will rewrite your font.xml and break your setup. It would be really nice to hear from one of the maintainers about non-English character support. I do believe I had to put the Arial font in /fonts but it has been a while (I got frustrated by the updates breaking my setup)
Added some fonts for other non-ASCII languages.
Japanese, Chinese, Korean, Thai, Arabic, Hindi, Burmese
Obviously they are preliminary, and need tweeking for size and placement, so if any natural speakers of these languages want to fix them up, by all means run with it.
Feel free to add anything useful to the official Metropolis. unofficial version
(some of the fonts can display multiple languages.)
Still having the issue in Helix. I just downloaded metropolis today. Previous fix still works.
I don't think the extra fonts were put into the official version. You will have to keep using your fix, or use my unofficial version. There are instructions at the bottom of my Git on how to install it.
There are pros and cons to doing either:
Using the official version means your fix will be undone with every official update that is pushed down.
Using mine means you will never get any updates pushed down.
It wasn't included in the official release because some of them looked incomplete and because you had said some still needed tweaking for size and placement. If anyone wants to clean it all up and turn it into a actual Pull Request on github I'd be happy to include it. I just don't personally want to take on the task of managing a bunch of different fonts, particularly if some of them need special exceptions for size/placement.
Additionally, the font choice for a skin is quite a big part of its design aesthetic. The fonts chosen would need to match that as much as possible.
