Full Version: YouTube Plugin - Can't Download
Hello,
I used to be able to download youtube clips using (right-click) download video, however it seems to hang on me now and not download anything. Looking at the log I see the following :
19:51:07 T:8996 NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Windows 7 SP1 64-bit, build 7601. Built on Dec 19 2013 (compiler 1600)
\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\DialogDownloadProgress.py:137: DeprecationWarning: object.__init__() takes no parameters
xbmcgui.WindowXMLDialog.__init__(self, *args, **kwargs)
19:51:39 T:8996 ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block C:\Users\shuttle\AppData\Roaming\XBMC\addons\script.module.simple.downloader
19:51:39 T:3900 ERROR: Exception in thread Thread-1:
File "C:\Program Files (x86)\XBMC\system\python\Lib\threading.py", line 532, in __bootstrap_inner
self.run()
File "C:\Program Files (x86)\XBMC\system\python\Lib\threading.py", line 484, in run
self.__target(*self.__args, **self.__kwargs)
File "C:\Users\shuttle\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 127, in _startDownload
self._processQueue()
File "C:\Users\shuttle\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 170, in _processQueue
status = self._downloadURL(filename, item)
File "C:\Users\shuttle\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 548, in _downloadURL
con = urllib2.urlopen(url)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 126, in urlopen`
return _opener.open(url, data, timeout)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 397, in open
response = meth(req, response)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 510, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 435, in error
return self._call_chain(*args)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 369, in _call_chain
result = func(*args)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 518, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 403: Forbidden
I am on windows 7 64 bit, and can navigate and play videos fine. If I use an extension of chrome I can download it fine as well. However, in xbmc, this seems to be now disabled and it was a nice convenience feature.
Any ideas?
Thank you.
I'm also experiencing trouble downloading from Youtube. I was able to download five days ago and now I cannot. Anyone know a solution?
I have the same problem, I was able to temporarily solve it by removing the temp file .xbmc/temp/commoncache.db
is there any other solution to this problem?
I also have this problem.
I have kodi running on Vista & Linux Mint & the problem is the same.
It was the same with Gotham before I updated.
Some content will play but nothing will download.
No message just hangs on preparing download.
