Full Version: XWMM on Minix Neo X7
Hi all,
Is it possible to install XWMM (as of this discussion) as an add-on in XBMC 12.4 on my Minix Neo X7 device?
I use firmware 008 and XBMC 12.4 (Frodo?) for Minix.
I activated the webserver in XBMC and tried to install another web interface but XWMM is not in the list.
The reason is that I really like to have an interface to edit my movie database.
EDIT: Oops, I read this post on how to install AWXi manually from a zip file. Can this also be done with XWMM?
Thanks in advance,
Erik
There is a XWMM thread in this same forum.
In it, you will find out that XWMM can only be installed from zip - it conveniently links to the zips as well.
Download the correct one on this page: https://github.com/slash2009/XWMM/releases
@Kib. Thank you, I should have done a proper search first. My excuses. I followed the "install from zip" procedure in this thread and I have the XWMM interface running right now. Was being to impatient...
