Full Version: Amazon Fire TV for XBMC
Whats the quickest way to enable usb with root. There was a tutorial a while back which was a little complicated?
Just a heads up for those who are not rooted. With the new firmware update, in order to access XBMC you can't just go to the system settings, applications section and then scroll down to the XBMC icon. There is now an extra section called "Manage All Installed Applications" that you have to click on before you can get to the sideloaded apps. Not a deal breaker by any means but still a minor annoyance.
(2014-06-25, 20:59)navigates Wrote: [ -> ]Whats the quickest way to enable usb with root. There was a tutorial a while back which was a little complicated?
sideload stickmount
so if i update my system, besides rooting again, what else do i need to do?
i just have xbmc (changed icons and sacrificed classic tv), stickmount to use USB external HD, llama, SU, es explorer
thanks
(2014-06-25, 21:46)dukester Wrote: [ -> ]
sideload stickmount
Stickmount is in google store? Will that root the firetv? Is this right?
(2014-06-25, 22:32)navigates Wrote: [ -> ]
sideload stickmount
you need stickmount for rooted fire tv to enable usb.
(2014-06-25, 23:13)yocoldrain Wrote: [ -> ]
(2014-06-25, 21:46)dukester Wrote: [ -> ]sideload stickmount
Can someone point me to the direction how to root firetv easily? thanks for stickmount
(2014-06-25, 23:28)navigates Wrote: [ -> ]
(2014-06-25, 22:32)navigates Wrote: [ -> ]Stickmount is in google store? Will that root the firetv? Is this right?
read the thread
(2014-06-25, 23:37)nickr Wrote: [ -> ]
(2014-06-25, 23:13)yocoldrain Wrote: [ -> ]you need stickmount for rooted fire tv to enable usb.
read the thread
I have read the thread. There were two sets of instructions. Which is the preferred method is what I'm asking.
Also would like the easiest method to root.
(2014-06-26, 01:16)Maric Wrote: [ -> ]Also would like the easiest method to root.
http://www.firetvnews.com/how-to-root-th...n-fire-tv/
(2014-06-25, 21:18)xiaNaix Wrote: [ -> ]Just a heads up for those who are not rooted. With the new firmware update, in order to access XBMC you can't just go to the system settings, applications section and then scroll down to the XBMC icon. There is now an extra section called "Manage All Installed Applications" that you have to click on before you can get to the sideloaded apps. Not a deal breaker by any means but still a minor annoyance.
Thanks for the heads up!
adbFire offers one-button rooting for the Fire TV.
(2014-06-26, 01:47)jocala Wrote: [ -> ]adbFire offers one-button rooting for the Fire TV.
I am not able to download adbFire in Chrome as they claim it is maliciuos.
