Full Version: xbmc crash upon start up
I've pasted it to:
I am just starting with XBMC and was trying to set it up. I couldn't get PVR to work so enabled another one. so two running now, I think that is the issue.
I have nothing really set up so I could erase everything and try again but it won't even let me do that. Every time that I delete xbmc and re install the same problem exists.
Sorry if this is a simple fix but I have spent hours on trying to fix it and can't
On a macbook pro if that helps
OS X 10.9.2 Launched by dmg
XBMC version 12.3 Frodo
Not sure about macs, but uninstalling xbmc leaves behind the userdata directory, you need to delete/rename that folder
Thank you so much! Thanks for teaching me how to wipe those user data files Smile
Very much appreciated
All good now
Reference URL's
