Full Version: A Couple of Questions
Just found this skin and love it!!!
is there a way to stop the name of the clip from popping up during the Cinema Experience when it goes through each step ie rating r or movie intro.avi
also is there a way to change "Concerts" to another name ie Video Clips
and finally where do I locate the skin as its not where confluence is as I would love the weather layout I have in confluence. I have the files if you need them to play with
also where does it pull the ratings of the movies I have as it seems to say a lot of my movies are R rated but they aren't. I have changed the MPAA to Australia.
cheers
Taza
ATM no way to stop the media name for popping up for a few seconds, may one day change it to an option but not high on the list.
Just redo the Concerts option and rename it to whatever you want.
The best way to get the MPAA correct is to use a scrapper like "Universal Movie Scraper" and set that to Aus. Also set the skin to use Australian images.
Skin is installed to your userdata folder - different OS's = different path's - Think there's a wiki page.
Thanks so much for that
Where in option can I rename concerts? Been looking
Cheers
Taza
