Full Version: Customization?
So i just started to use this skin with the gotham build on my Ouya.
I like it so far, but is there anyway to remove for example music and weather and picture
on the home screen since i dont use my xbmc for those, was using Ace before had alot of customization.
<3
All the conditions were coded to hide whatever you wanted I just forgot to add the settings. Wink
All done for v0.9.3.
is it also possible to change the pic of movies, tv shows on the homescreen?
+1
I would also like to know how to change the home images.
Same. I mentioned it in the other thread. IMO, the current ones don't really match the rest of the skin. Something stylized and monotone would look great, I think.
