Full Version: unable to connect - xbmc on a mac
Downloaded Xbmc on my mac - no problem. Tried tried to add fusion but says unable to connect to the internet. Went to check connection in system info and it says connected. Anyone with any idea how to fix this? Have removed - including the file in the library - and resinstalled xbmc but still the same problem.
Added 4od and other video add-ons and these work ok..thus proving the internet connection is ok. It just won't work when I try to add fusion or xfinity?
Problem solved! It was a safari setting problem. Needed uncheck the 'Open safe files when downloading' box in safari preferences 'General' tab.
