2014-04-21, 16:50
I was trying to play a movie when I realised it didn't look fine. The movie was played in a Macbook pro retina (late 2013).
This movie is the only one in which it happens. I mean what happens arround his upper-body, those blue and red lines.
Mac Tech specs
2,4 GHz Intel Core i5, Intel Iris 1024 MB
XBMC 12.2
log
Video info
General
Unique ID : 219812204185802005762432178911332543107 (0xA55E4A65F652E5A38985B994BC2C2A83)
Complete name : /Users/Jaume/Desktop/Iron Man 3.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 4.98 GiB
Duration : 2h 11mn
Overall bit rate : 5 427 Kbps
Movie name : Iron Man 3 [www.newpct.com][toni32]
Encoded date : UTC 2013-08-20 21:38:42
Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 11mn
Bit rate : 4 551 Kbps
Width : 1 916 pixels
Height : 796 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.124
Stream size : 4.17 GiB (84%)
Title : Iron Man 3 [www.newpct.com][toni32]
Language : Spanish
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Playing it with VLC it doesn't happen so, there is no problem with the file
Click here for higher quality image
Thank you very much in advance and forgive me if it is not the right place to post it, I'm quite new.
Mac Tech specs
XBMC 12.2
log
Video info
General
Format : Matroska
Duration : 2h 11mn
Video
Format : AVC
Duration : 2h 11mn
Height : 796 pixels
Color space : YUV
Bit depth : 8 bits
Language : Spanish
Default : Yes
Forced : No
