I'm going to give this a whirl in the latest Gotham Beta.
I am very interested in this plugin.
Thanks for the effort.
Meyv will not install...it stops abruptly and does not complete install.
(2014-04-24, 01:16)kashkow Wrote: [ -> ]Meyv will not install...it stops abruptly and does not complete install.
Can you put your log in xbmclogs.com and let me know what version of xbmc and the platform you're running on. I've tested with the latest Gotham beta and 12.3 under windows and linux and haven't had problems so I need to have a look. Thanks. It's odd that it doesn't even install as the only dependency in addons.xml is the python version.
When issues like not installing happens, I usually have good results by just pasting in the extracted folder into plug-ins and let the "magic" happen.
If I remember I'll post my results using WIN7 Gotham beta 4.
(2014-04-24, 02:05)learningit Wrote: [ -> ] (2014-04-24, 01:16)kashkow Wrote: [ -> ]Meyv will not install...it stops abruptly and does not complete install.
When I tried to install from the xbmc.org repo, I got an error the first time. The second time it loaded fine. I need to find out what causes an MD5 mismatch error, but it could just be that everything hasn't been updated in the xbmc repo yet. You can also download directly from my repo:
https://github.com/learningit/plugin.video.metv/
Worked fine installing 1st try from the zip for me.
I got the file from the link you posted.
That site loads real quick.
As you would expect, they are low quality but very watchable.
I keep looking for an ORA TV plug-in.
(2014-04-24, 03:19)aksarge Wrote: [ -> ]Worked fine installing 1st try from the zip for me.
Some of the ORA site can be done, but the Hulu content is a real problem.
Thanks learning i will try that if that does not work I will post log..I love METV!!!!!! Got to have it...you guys are amazing whenever you need donation I will give!!! You guys deserve it!!!
(2014-04-24, 03:38)learningit Wrote: [ -> ] (2014-04-24, 03:19)aksarge Wrote: [ -> ]Worked fine installing 1st try from the zip for me.
I forgot about the ORA / HULU "connection".
I finally got the moths and cob webs out of my wallet and got a mohu indoor antenna.
My "manroom" is our dug out and finished off crawl space.
It doesn't even qualify as a daylight basement. Zero windows and all below grade.
ANYWAY......The $35 mohu gets all the channels I want AND METV.
I had no idea we had that here in Anchorage
I cut that cable tv cord 2 years ago and haven't looked back.
MeTv Addon updated, all videos are now slightly higher resolution, the old was 540x360@321kbps, the new is 720x480@721kbps. The colour videos are quite a bit better. Version 1.1.1 is in my repo now:
Should be updated in xbmc.org repo in the next couple of days. Enjoy!
UPDATE: version 1.1.2 in my git above fixes a bug in the Classic Commercials which was causing crashes.
Updated version V1.4.0 in my git and has been submitted to the kodi.org repo.
This version adds metadata, subtitles and user selectable views.
The view values are set for the ftv skin and can be modified in addon settings.
This makes the addon look much better under different skins. For ftv skin just enable Views in the addon settings and you should be good.
I've updated but the content in it never changes, is there anything i need to do to get other content? thanx.
