2014-04-27, 03:59
2014-04-27, 03:59
2014-04-27, 22:13
The only explanation I have is that you are running a skin that does not yet have the Gotham menu settings option and you aren't in at least Advanced or Expert mode. Switch to Confluence (if applicable to you) and confirm. The clean library option is visible to me with Confluence in those two levels. Puzzling....
2014-04-27, 23:19
(2014-04-27, 22:13)clipper99 Wrote: [ -> ]The only explanation I have is that you are running a skin that does not yet have the Gotham menu settings option and you aren't in at least Advanced or Expert mode. Switch to Confluence (if applicable to you) and confirm. The clean library option is visible to me with Confluence in those two levels. Puzzling....
Aaaah that was it. Thanks, had to change to expert.
