Full Version: Playing Youtube links in XBMC
Im putting together a basic plugin for a friend, it will be a static list of Youtube links.
So far i am unable to get youtube links to play in XBMC,
should i be importing the youtube addon within my own in order to prepare the videos for viewing, or should they just play if i have the correct URL?
this is where i am at currently
import sys
import xbmcgui
import xbmcplugin
addon_handle = int(sys.argv[1])
xbmcplugin.setContent(addon_handle, 'movies')
url = 'plugin://plugin.video.youtube/?action=play_video&videoid=GgTpAPdwmbU'
li = xbmcgui.ListItem('Addison Groove Tribute', iconImage='http://www.residentadvisor.net/images/reviews/2012/addison-groove-transistor-rhythm.jpg', thumbnailImage='http://www.residentadvisor.net/images/reviews/2012/addison-groove-transistor-rhythm.jpg')
li.setProperty('fanart_image', 'fanart.jpg')
xbmcplugin.addDirectoryItem(handle=addon_handle, url=url, listitem=li)
xbmcplugin.endOfDirectory(addon_handle)
Any advice would be much appreciated.
So looking through other plugins, ive found that i need to translate the URL before sending it onto XBMC
This link:
http://r5---sn-cg07luee.googlevideo.com/...=m&mws=yes
Content wise, Is the same as this link:
which was grabbed from youtube as
https://www.youtube.com/embed/GgTpAPdwmbU
Trying to work out how to convert from one to the other.
Any ideas?
Quote:You can use the Youtube addon:
url = "plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=YOUTUBE_VIDEO_ID"
Really banging my head against a brick wall now
Every example i find on the forum doesnt work anymore.
But i can play the videos using YouTube or YouTube Channels plugins. Even replicating the path to a working video doesnt work.
What version of the YouTube add-on are you using? I have 4.4.6 from The Collective and this works fine for me:
plugin://plugin.video.youtube/?action=play_video&videoid=VIDEO_ID
(Granted, I used it from a context menu, so it's wrapped with PlayMedia(), but you wouldn't need to do that.)
EDIT: You may also need to set
li.setProperty('IsPlayable', 'true')
