Full Version: XBMC close, when hitting play on any channel!
Dear All, first post in Myth section.
Got Mythbuntu up and running and can see some of my channels in Myth frontend. But when I try in XBMC, I have issues!
XBMC loads EPG and channels on XBMC start up (so there is connection), but when I hit any channel in XBMC then XBMC start thinking a bit (the spinning clock) and then just close 2-3 secs later!
So what should I check?
Gonna check later the versions I got installed!
I have had ever
One note,
I run the MythBuntu + XBMC from USB stick on same machine but as the Myth Frontend works I assume this is not the issue with the USB stick?
what tuners do you have? what version of xbmc are you running? can you actually play any of the channels when in myth-frontend?
can you please post an xbmc.log file. post it at pastebin or similar and post the link here for us to view your log.
Got it solved! So an error on my side :-)
