Full Version: Master Thread for Guides, Tutorials, and Common Problems on Windows
SECTION 1 - BEFORE ASKING FOR HELP
Before asking for help on the forum please read the following.
A. USE THE FORUM SEARCH BUTTON
8 times of out 10 your question will have already been asked, please use the SEARCH function to find previous posts on the subject.
Forum Search
If you not able to find anything relevant using the forum SEARCH then please also try the following Google Search
Google Custom Search of Kodi Forum
B. READ THE Kodi Wiki Manual AND THE FAQ (Frequently Asked Questions with Answers)
The wiki contains loads of information that might not be covered on the forum.
Make sure to check the following:
Kodi Wiki Manual
All Platforms FAQ (Frequently Asked Questions with Answers) - FAQ that applies to all versions of XBMC.
Windows FAQ (Frequently Asked Questions with Answers) - Windows OS specific FAQ.
C. THIS IS NOT THE MICROSOFT WINDOWS HELP FORUM
Yes we will try to help out, but please don't ask basic windows questions like how to copy a file to my NAS or how to I edit an xml file, that's beyond the scope of this forum.
D. IF YOU HAVE A PROBLEM WITH A OLD OR STABLE RELEASE OF Kodi (or XBMC)
Try either a Beta or RC builds (if available) from:
http://mirrors.kodi.tv/releases/win32/ - These are the stable releases.
or a Nightly build from:
http://mirrors.kodi.tv/nightlies/win32/ - These builds can be very unstable
These builds will contain fixes and new features that are merged in between official releases and will potentially fix an issue you might have.
As always, be sure to backup your userdata folder regularly when playing with nightlies or monthlies.
HOW TO - Fix Loss of HDMI Audio After Resume from Sleep Using EDID Override
This tutorial is to address the loss of sound caused by the disconnection of an audio device after Windows resumes from Sleep. This commonly occurs when display and audio devices are connected via HDMI to a PC. Although the device is connected, Windows believes it has been turned off and sound is cut-off. A reboot of Windows will fix this issue in most cases, but this is not a permanent solution. This happens most often when Windows is put to Sleep rather than powered off completely.
HOW TO - Solve audio problems + video stutter (audio induced)
Covers typical problems introduced by incorrectly configured audio
No Audio
Video stutter
Video choppy
Video jerky
Slow playback
No HD audio either DTM-MA audio or TruedHD audio
Slow frames per second ( FPS) when playing video
WASAPI crackling or distortion (see Section 7)
Low volume on PCM track or when transcoding (see Section 7)
Dolby Digital Plus (EAC3) can't currently be bitstreamed for decoding on a AVR, however it can be decoded within XBMC to Multichannel LPCM by unselecting the option "Dolby Digital (AC3) capable receiver"
HOW-TO use a Logitech Harmony Remote with XBMC
Guide to setting up Logitech Harmony for XBMC
IR / RF Remote Controls for Windows: Links to Explanations, Tutorials, and Guides
Tutorials and guides for getting your remote control to work with XBMC for Windows.
Black Screen when fullscreening
Problem with black screening on video playback
