Full Version: Xperience1080 3.x
Xperience1080 3.50.00 is for Kodi 14.x "Helix" only
Now available from the official repository.
watch gallery
Installation
  1. Download Kodi 14.x
  2. Go to Settings -> Appearance -> Skin -> (Select current skin) -> Get More... -> Xperience1080
  3. The screen may go blank for 10 seconds to 1 minute, this is normal.
  4. Dependencies will be automatically downloaded, installed and enabled.
  5. You will be asked if you would like to keep the new skin, select Yes.
  6. IMPORTANT: If you are moving from 1080XF to Xperience1080 please read below.
Weather Fanart
  1. Download the Fanart pack from here.
  2. Enter the weather section and make sure you're using OpenWeatherMap Extended.
  3. Press down/up to open the menu.
  4. Untick 'Hide fanart'.
  5. Select 'Set fanart path'.
  6. You'll now be presented with a dialogue to choose the location of the extracted images you have just downloaded.
  7. Point it to that directory as instructed in the Fanart thread.
  8. That's it, you should now have the full weather display. You may need to restart Kodi.
Changes in 3.50.x.
  • Trakt add-on dialogue integration.
  • Playlists fixed for widgets.
  • All panels resized to use the best of Xperience1080 but allow for less wasted space.
  • Removal of the hideous 'stats' panel in Settings.
  • Extended widget support for Upcoming Movies, In Theatres, Popular Movies, Top Rated Movies, Trending TV Shows, Trending Movies.
  • Correctly user-translated strings (several languages)
  • Corrects skin support for the Home Theatre add-on.
  • Various fixes to Kiosk Mode.
  • Fixes to all areas of the File Manager.
  • Small visual progress indicator added to now playing media when pressing M.
  • Various fixes to TV Tunes + labels + Skin Settings.
  • Optional Coloured Home Tiles.
  • Option to disable stream and file path (disabled as default).
  • Changes Song Count to Album count (requested more than once).
  • Corrects Search going to Power button instead of Search 'bar'.
  • Adds an option to reset the skin to default settings, use with caution.
  • Special episodes now show season number.
  • Ability to select custom overlay + 12 new ones to choose from.
  • Optional Left/Right arrows on the Home screen (helpful for children or new users).
  • Removal of unwanted Pause Icon.
  • When absolutely no library content is available in Home widgets, a new icon and text is shown so the user understands.
  • Kiosk mode fixes (Favourites etc).
  • Fix of Library scan status not updating when changing views.
  • Home Weather updates for users without artwork.
  • New Lyrics window and multiple music section fixes.
  • New variables for each Banner viewtype.
  • Fixed aspect ratio textures not displays for 2.40:1 and two others.
  • Profiles section now matches design of other Settings areas.
  • Conditional Profile Image strings - example: when Movies is disabled the text will now not display the Movie count.
  • Episodes unwatched count now corrected throughout skin.
  • Fanart now disabled in TV Guide when option selected.
  • New Home layout - reduced width and more widget spaces.
  • Re-worked Skin Settings to make more sense.
  • + over 420 commits since the last version fixing multiple issues.
Known issues
  1. non-EN languages not all updated (see Transifex below for details).
  2. A few small issues when first using the skin, will be resolved (are described below).
Moving from 1080XF to Xperience1080
  1. If you have already have Xperience1080 installed, you'll need to reset your skin settings (Skin Settings -> Advanced -> Reset Skin)
  2. If you don't see the correct language strings, please select another language, then go back to yours.
  3. The default texture set is now Xperience1080, you can select 1080XF from the Themes part in Appearance.
  4. You will lose your skin customisations, sorry about that. I won't be changing the name of the skin again.
Note: You can continue to use 1080XF, if you're happy with it. It won't be supported, however.
Moving from the Xperience1080/1080XF Beta to Xperience1080 repository
  1. If you've been testing the Xperience1080 beta, you shouldn't need to do much. Your settings should still work (the repo version is the last stable testing version).
  2. If you've been testing the 1080XF beta, you'll need to follow the above.
Translations
If you don't see your language available, or it has issues, please read this thread: http://forum.kodi.tv/showthread.php?tid=218279
Reporting an issue
Please make sure you include a screen shot and detailed description in this thread.
Special thank you to:
  1. xhaggi
  2. `Black
Want to buy me a beer/coffee/pizza?
USD and GBP are also accepted Rolleyes.
I love the Xperience1080 skin already on itself, but also there is room for a flat version.
Really looking forward for your release, always love flat modern UI's.
Great job.
it is really beautiful I will wait it and i hope it compatible with Gotham
(2014-06-06, 01:16)mody5555 Wrote: [ -> ]it is really beautiful I will wait it and i hope it compatible with Gotham
It will work with Gotham 13.1.
The only part I'm having an issue with is the screen calibration option, `Black if you see this I would appreciate a small nudge to help me resolve the issue - all the images are stretched, but the main problem is the A/R. I'll continue to dig around and see what the issue is.
this looks great. can't wait to try it Tongue
I like it, gives it a modern metro look.
LOVE IT !!! Smile Nice work mate as usual ...
awesome!
Looking good, I'll certainly give this a shot!
Any chance you add the use of XBMBC3 like 1080 ++
Perhaps you could put it on Github, and allow people to install it already on Gotham so they can provide feedback on Github itself making it easier to spot bugs or feature requests.
I plan to either create a repo or put it on git, or both. Also I don't want to let anyone use it yet as, frankly, I'm a perfectionist and want to make sure each pixel is correct. Once I'm reasonably happy with it I'll put a zip up just for testing followed by setting up git and the repo.
Added note:
- not all images will be 100% new, but all will be changed. An example is the 99 images used for the progress indicator (volume wheel, now playing etc) - I've removed the shadow from each one so it's 'flat' but believe the gradient should stay. If people don't like this I can change it. I may decide to change it, meh. Hoping to post more screenshots later on this evening of fully completed areas.
edit: I don't mind creating a zip for PM, I would rather not but I understand extra eyes are always useful. It WON'T be finished but will be complete. If you would like the current version please send me a PM, I really hate releasing unfinished work.
For anyone interested, here is a side by side comparison of the new image vs. the current image used for one icon:
(2014-06-06, 21:44)saitoh183 Wrote: [ -> ]Any chance you add the use of XBMBC3 like 1080 ++
I'm sorry but my skills don't go anywhere near that far. Basic fixes and graphics are my two areas for XBMC.
(2014-06-07, 21:16)Piers Wrote: [ -> ]
ah ok, well maybe some one will decide to port it...if i knew how , i would in a snap Smile
