Full Version: No thumbs in bookshelf on rasberry pie
Hi.
I have a question about the home screen bookshelf on the pi.
In the recently added bookshelfs for movies and also TV, I dont get any thumbnails/cover art. Just place holder images. I can I fix this?
If I go into the recent show link, they are all listed there..
Also, the episodes are all labeled S0XE0X format, but it doesnt tell you the title until you select one. Is there anyway to make it display the show title instead? I couldnt find the option in the skin settings.
Last question, when I added my TV shows folder on initial setup, some shows werent added in the show real, but were visible in the file list. Any ideas why?
Thanks in advance
I think this is an issue with season art not being downloaded. This PR does seem to resolve the problem:
https://github.com/xbmc/xbmc/pull/3546
But unfortunately @jmarshallnz is not happy with it.
You could try a Milhouse build which includes the PR (http://forum.xbmc.org/showthread.php?tid=192380) but be aware that is a Helix test build (like a nightly build)
so may cause other issues.
(2014-06-06, 13:37)popcornmix Wrote: [ -> ]I think this is an issue with season art not being downloaded. This PR does seem to resolve the problem:
So, many months later we finally get to know what the problem seems to be. Thanks for posting this info.
