I've moved my setup to have ServerWMC centrally hosted using 2 PCIe TV Tuner Cards with 2 Tuners each giving 4 DVB-T Tuners in total.
Sometimes the channel plays ok to all clients, other times not and I get a No Video data found on this channel error in XBMC. This happens on all clients, as I say sometimes it works, sometimes it doesn't.
One curious thing, ServerWMC is reporting 12 Tuners, where I would expect it to say 4. Could this be the cause? It is trying to use a tuner with no video to stream the channel?
(Streaming currently OK to LoungeTV on the screenshot, logs below are from before so this is not included)
My cards have some FM Tuners which I guess are taking it from 4 to 12.
In WMC it works flawlessly on the host. I have tried ServerWMC 1138 and the new 1150 both give the same result. All clients are running the latest XBMC PVR 0.2.95.
Logs attached from my test just now.
http://pastebin.com/7NgHgHzm
I think the 1st 3 times to Martins-V3772G were OK, the last 2 times not ok.
Any ideas?
Cheers
Going to need to see what krusty has to say about the tuner count thing, but we do now support FM tuners so what you're saying does make sense that it could explain the count going up to 12. Although really it doesnt seem to quite explain it given that 2 twin tuners should be 4 DVB-T and 4 FM tuners, meaning a total of 8! I think we may have a counting bug there as if you look at your log in the EnumerateRecorders section we are listing each tuner as DVB-T and radio, then we list the 4 radio ones again, and THAT total would be 12. so the radio ones are probably being counted twice. I dont think this has any bearing on your problem though
From your log my observations are that for the attempts that worked and the ones that failed, the same tuner (#1 DVB-T with a guid ending in 91755fd164a6) was being used in all cases, so I dont think there is a problem with grabbing a tuner that cant tune the channel, or the above radio count stuff having any impact on this. The times when things worked OK, the video and audio tracks were identified correctly, but I do note that things seemed to be quite slow with it taking 5 seconds for data to start flowing and then 2.4 seconds to analyze the streams and get the remux happening. Normally id only expect a few seconds... The 2 later times when it doesnt work, is because it took over 8 seconds just to start seeing data, and the the video stream had been found but not yet identified, when the WaitForTS time out (default 10 seconds) hits and the operation is cancelled. You can increase the timeout to a larger value (eg 20 seconds) which might help with getting the video stream identified and allow the operation to complete, however it's surprising to see such long times involved. How quickly does WMC change channels with this? How quickly does WMC start recording something when you tell it to? Can you run XBMC locally on the server and report on how things are there? I guess it'd also be interesting to know the vital stats of the server machine (cpu ram HDD) and also how your network is setup (speed/type of connection)
Anyway, if you want to up the time out, edit the config file (see Debug tab in ServerWMC) and find the line
<Timeout_WaitForTS_MS>10000</Timeout_WaitForTS_MS>
Change the value to say 20000 for seconds and then have a look at your logs again. One possibility is it just needs more time to identify the video stream. Another possibiliy of course is that something weird is happening and it doesnt matter how long you wait, it would never identify properly. If that was the case, then getting you to upload a sample WTV file would be a good thing, but let's see how you go first.
Also if you wanted to try and simplify your setup you could go into WMC and "untick" certain tuners (I dont have ones that support FM but if this showed up as a separate tuner in WMC you could untick it and then ServerWMC probably wouldnt see/count it) and also "untick" any channels you dont want to see in XBMC (I notice alot of your channels seem to have no EPG listing etc anyway). This may not help anything in terms of your slow speeds to get tuner data but perhaps it makes things clearer if the extra noise/cruft is not getting in the way?
Hey
Thanks for replying so quickly. I wasn't sure of the Tuner issue, just saw WMC said I had 4 and ServerWMC said I had 12 so presumed it was trying to use a tuner ServerWMC thought it existed but didn't hence working sometimes but not others. But as you say its trying to use the same tuner in the logs so must be totally unrelated.
Some channel changes do sometimes take longer than others, quickest around 5 secs, sometimes can delay to 15 secs. I guess this is where the time out would occur and the channel wouldn't play. I have modified the timeout to 20 secs and now all seems OK. I will test a bit more.
I will test WMC channel change times on the Server later tonight as didn't pay much attention. I do remember it taking a few seconds to tune from the guide when I was testing it last night.
Server is not a bad spec,
Win 8.1
Core i5-4440 @ 3.10GHz
8GB RAM
Dedicated 1TB HDD for TV Storage keeping it separate from the RAID5 with all my other Music/Movies. OS is on another partition on this RAID5 but is snappy enough.
RAID card is the LSI 9260-8i Hardware RAID.. but anyway as I say TV Storage drive is set to the dedicated 1TB HDD.
I am using 2 old Pinnacle 3010ix Cards with the AverMedia drivers from Win 7 64 bit, The Pinnacle drivers don't seem to like Win8. Seems to work OK but they are old cards so possibly the cause.
Server is Wired Gigabit but I haven't updated the NIC Drivers, ill try this. Clients are mix of Wired Gigabit and Wireless 2.4 and 5ghz.
The radio tuners are getting double counted, apparently there are two different ways wmc can report their existence - I thought there was only one (at least on my system there is only one). I will have to fix this, but like scarecrow says its not causing your problem with tv. Thanks for posting the log.
Thanks Guys. I can't find the option in WMC to choose which tuners to use sorry. I tested channel switching in WMC on the Server, it took about 5 seconds from Guide to channel, then about 1-2 seconds moving up and down channels. 15 Second channel switch on XBMC doesn't bother me as we don't switch up/down, just use the EPG as long as it tunes reliably, which it is now doing since I set the timeout higher.
Nothing really running on the Server, CPU is at 1-2% with ServerWMC Streaming and all disk activity dead apart from the dedicated TV Drive @ around 2% activity. Not sure why my logs are showing slower than normal tuning but hey its working now and I can live with the odd 15 second tune.
Recorded shows start instantly.
From your logs I thought you were using the avermedia cards but now you mention you are using older cards with those drivers etc I would think that's probably related to the slowness. The way we use the tuners is to initiate recording of the channel, then remux the WTV to TS. So eventhough in WMC you may get a faster response on live viewing that's because it directly accesses the stream (and we cant get at that from ServerWMC). I would suspect that (if there was some way to measure it) recordings done in WMC would be seeing similar delays in terms of how long it takes for data to actually start being written to the WTV file. Anyway if increasing the timeout works for you and you aren't bothered by the lengthy time to start streams, Im glad you now have a reliable setup. Im sure that with new tuner hardware you would get some better responsiveness so keep that up your sleeve for if/when the time comes, or you want to try and get a better response time on stream starts. Oh and the specs of the machine sound more than adequate, I don't think there's any improvement to be had there (the times I am mentioning are to write data to the local WTV file, so NIC drivers or network stuff isn't going to affect that).
Yeh it was the old tv tuner cards. Just tried an Avermedia A850 USB Tuner and channel change is always around 5 seconds. If I were to keep this SD tuner and also connect 2 x DVB-T2 USB tuners do you know how xbmc/serverwmc would handle this? If I selected a program to record on a HD channel would it always try the DVB-T2 tuner first? If I selected a program to record on an SD channel would it try the DVB-T tuner first?
Cheers
In wmc you can set a preferred order for tuners so that it always tries your favorite tuners first, and only uses the others if there is a conflict. Serverwmc uses the same order for live-tv. Also I believe you can set wmc to always try to record a program in hd if possible.
Keep in mind there is a limit of I think, 4 tuners, in WMC unless you hack it with "TunerSalad". Im not too familiar with differing broadcast formats since in Australia we only have DVB-T. Wouldnt it be better to just use the fast USB tuners for everything? Or are there some channels that ONLY your slower pcie tuners can handle, but you want to make sure they are only used for those channels and not for channels where your "better" tuners can also do that channel?
Certainly ServerWMC/WMC will only select a tuner capable of servicing the desired channel you select, so there's no worry of picking a tuner that doesnt work for the channel you wanted to watch, but if multiple tuner devices support the channel, we most likely just pick "the first unused one" as seen in your logs, all the requests were using "tuner #1". Im not sure if you can adjust the order in which the tuners appear to us, you can certainly SEE the order in the ServerWMC log when it starts up and does it's "enumerating tuners" output.
I believe you can also get pretty fancy in WMC by messing with the tuning spaces and frequencies and tuner priority, underneath the advanced settings of each channel. ServerWMC should honour all stuff setup in WMC, we have had some users that had pretty complex customised setups earlier on, and we made more changes to ensure we imported the tuning spaces, frequencies, tuner priorities etc correctly from WMC
Hey
Thanks. Yes this is what I was thinking of doing. I was going to remove the old PCIe tuners altogether and use the AverMedia A850 DVB-T USB. I have 2 x August DVB-T210 DVB-T2 USB tuners on the way. This would give us 3 tuners in total for 2 main clients which would be fine and I can also add another usb tuner later if needed.
Thanks for your support guys.. it's amazing. Great appplication as well. I wouldn't have made the move from WMC to XBMC if it wasn't for your PVR Addon.
Hi, Had the same problem when I upgraded my XBMC to Goitham 13.1 and ServerMWC 1150. It was reporting I had 6 tuners when I should have 4 (2 DVB-T, 2 FM). I downgraded ServerWMC to 1138 - same issue but once I installed 1137 all was reporting correctly again - 4 tuners and I am able to watch LiveTV from XBMC again.
Seems a change introduced between 1137 and 1138 is causing this issue. Hope you can identify the issue as I am very happy with your software and hope tobe able t get updates again in the future.
Weird. Please post the serverwmc log for the case where it is over counts the tuners. I'd prefer it if its the newest version, if you can, To post a log, see the debug tab to find it, and upload the log to pastebin.com and paste a link to it here.
So you are saying when it over-counts the tuners live-tv doesn't work? If so, make sure in the log you post that you have one attempt at trying to start a live stream.
(2014-06-16, 23:59)krustyreturns Wrote: [ -> ]In wmc you can set a preferred order for tuners so that it always tries your favorite tuners first, and only uses the others if there is a conflict. Serverwmc uses the same order for live-tv. Also I believe you can set wmc to always try to record a program in hd if possible.
hello
Your software is really great. I installed the new tuners and the same problem occurred.
I think I found where does the problem may be in.
I'm with the 1175 release.
I always disables mcGlidHost.exe (mcGlidHost.exe scanned the frequency used to find new channel, take the "best" frequency according wmc and recover the missing epg on DVB-T wave) because wmc is bad usual frequency, but it works on wmc not disable "mcGlidHost.exe" so I left, I have the guide on some channel that there would not be if I had is disable.
You gave me the idea of putting as I did before that is to say to the frequencies that works best she eventually "xxx, 167MHz" and this way your software works. I sends you the logs with a frequency other bad with the good.
ps: If I put the frequency of "xxx, 167MHz" leaving lit mcGlidHost.exe wmc will not do than it head and change the frequency. If I disables mcGlidHost.exe, I no longer have the epg on some channel
work "xxx, 167MHz"
2014/12/11 18:52:04.602 OpenLiveStream> -----------------start------------------------
2014/12/11 18:52:04.602 OpenLiveStream> client: Julien-PC requesting live stream
2014/12/11 18:52:04.618 LiveRemuxStream> live-tv started
2014/12/11 18:52:04.619 SetChannel> Channel: 8 : D8 - 54129B = { (8 : D8 - 541292) + [ 8 : D8 - 5412D3, 8 : D8 - 541309, 8 : D8 - 54133F, 8 : D8 - 541375] }
2014/12/11 18:52:04.620 SetChannel> Tuners available for this channel: 6
2014/12/11 18:52:04.620 SetChannel> Tuner DecoyMethod: OnDemand
2014/12/11 18:52:04.620 SetChannel> ---
2014/12/11 18:52:04.621 SetChannel> Attempt: 0, Tuner: Hauppauge WinTV-HVR 713X BDA DVBT Tuner / 93defc4b-becc-4f25-a088-f14c1ec34274
2014/12/11 18:52:04.621 SetChannel> > Encrypted: False
2014/12/11 18:52:04.630 SetChannel> > RecorderInfo found: True
2014/12/11 18:52:04.631 SetChannel> > Recorder Content Protection: PROT_COPY_FREE
2014/12/11 18:52:04.632 SetChannel> > Status: Available, client:
2014/12/11 18:52:04.632 SetChannel> *** requested number of available tuners found, stopping search ***
2014/12/11 18:52:04.632 SetChannel> ---
2014/12/11 18:52:04.632 SetChannel> available tuners found: 1 [decoys:0], requested: 1, searched: 1
2014/12/11 18:52:04.632 SetChannel> Tuner: Hauppauge WinTV-HVR 713X BDA DVBT Tuner will be used for the live stream
2014/12/11 18:52:04.636 SetChannel> Recorder acquired: True
2014/12/11 18:52:04.639 SetChannel> TuneRequest set
2014/12/11 18:52:04.712 LiveRemuxStream> wtv recording started in 0,09 sec
2014/12/11 18:52:04.712 LiveRemuxStream> stream output file: LiveTV_Julien-PC_DVB-T_8_2014_12_11_18_52_04.ts
2014/12/11 18:52:04.713 LiveRemuxStream> started remux thread: 'D8-8:5509787'
2014/12/11 18:52:04.718 Remux::FindDescriptors> Scanning wtv for streams...
2014/12/11 18:52:06.781 Parse> Guid: 0 took 2,06 sec, it was attempted 1019 times
2014/12/11 18:52:06.781 Parse> Next 4 Guids: 0,00 sec, 0,00 sec, 0,00 sec, 0,00 sec,
2014/12/11 18:52:07.337 Parse> Descriptor pass done, using 683 guids in 0,56 sec
2014/12/11 18:52:07.337 Parse> Total Descriptor parse time: 2,62 sec
2014/12/11 18:52:07.337 Pass 'Descriptor':
2014/12/11 18:52:07.337 > WtvToPesDemuxer::Parse> total guid headers processed: 683
2014/12/11 18:52:07.337 > WtvToPesDemuxer::Parse> total data packets processed: 108
2014/12/11 18:52:07.337 Remux::FindDescriptors> wtv scanned (2,62 sec), Streams found:
2014/12/11 18:52:07.337 > SubTitle: ID:65 Subtitle
2014/12/11 18:52:07.337 > SubTitle: ID:66 Subtitle
2014/12/11 18:52:07.337 > Audio: ID:67 (eng) mp3 V1L2 Stereo 48000 Hz 192 kb/s
2014/12/11 18:52:07.337 > Audio: ID:68 (fra) mp3 V1L2 Stereo 48000 Hz 192 kb/s
2014/12/11 18:52:07.337 > Video: ID:69 mpeg2video MP-ML 720x576i fps: 25 AR: 16:9
2014/12/11 18:52:07.337 Remux::FindDescriptors> languages other than 'fra' removed: 1
2014/12/11 18:52:07.337 Remux::FindDescriptors> Output streams:
2014/12/11 18:52:08.054 LiveRemuxStream> 'ts' file created, size: 196 608 in 3,34 sec
2014/12/11 18:52:08.054 LiveRemuxStream> total time: 3,44 sec
2014/12/11 18:52:08.077 OpenLiveStream> stream path returned to client: smb://htpc-julien:*******@Htpcjulien-pc/d/TV enregistrée/TempSWMC/LiveTV_Julien-PC_DVB-T_8_2014_12_11_18_52_04.ts
2014/12/11 18:52:08.078 OpenLiveStream> -----------------done-------------------------
2014/12/11 18:52:08.086 Finished request OpenLiveStream in 3,49s
2014/12/11 18:52:19.937 Received client request: Julien-PC|192.168.0.27|CloseLiveStream
2014/12/11 18:52:19.938 CloseStream> -----------------start------------------------
2014/12/11 18:52:19.938 Remux::Stop> stop remux requested
2014/12/11 18:52:19.939 WtvToPesDemuxer::Parse> Guid header detects stream end
2014/12/11 18:52:19.939 Pass 'mux2ts':
2014/12/11 18:52:19.939 > WtvToPesDemuxer::Parse> total guid headers processed: 7 486
2014/12/11 18:52:19.939 > WtvToPesDemuxer::Parse> total data packets processed: 1 187
2014/12/11 18:52:19.945 Remux> ENDED, >>>>>>>>>> Run Time: 0,21 min <<<<<<<<<<
2014/12/11 18:52:19.958 LiveRemuxStream::Close> remux stopped successfully
2014/12/11 18:52:20.008 DeleteTS> ts file size: 8 028 160
2014/12/11 18:52:23.423 LiveRemuxStream::Close> ts file deleted: D:\TV enregistrée\TempSWMC\LiveTV_Julien-PC_DVB-T_8_2014_12_11_18_52_04.ts
2014/12/11 18:52:23.423 RecordToWTV::Close> isPassive is False => COM recorder will be stopped
2014/12/11 18:52:23.499 LiveRemuxStream::Close> wtv closed successfully
2014/12/11 18:52:23.550 LiveRemuxStream::Close> wtv file size: 11 010 048 (0xA80000)
2014/12/11 18:52:23.550 LiveRemuxStream::Close> wtv file deleted: D:\TV enregistrée\TempSWMC\LiveTV_Julien-PC_DVB-T_8_2014_12_11_18_52_04.wtv
2014/12/11 18:52:23.550 LiveRemuxStream::Close> closed in 3,61 sec
2014/12/11 18:52:23.550 Close> closed stream for client: Julien-PC
2014/12/11 18:52:23.551 CloseStream> -----------------done-------------------------
2014/12/11 18:52:23.553 Finished request CloseLiveStream in 3,62s
2014/12/11 18:53:47.465 MaintenanceTimer> callback at 18:53
2014/12/11 18:53:47.466 MaintenanceTimer> callback - complete
2014/12/11 18:53:51.106 Received client request: Julien-PC|192.168.0.27|GetTimers
2014/12/11 18:53:51.599 Finished request GetTimers in 0,50s
2014/12/11 18:53:51.614 Received client request: Julien-PC|192.168.0.27|GetRecordings
2014/12/11 18:53:52.302 Finished request GetRecordings in 0,69s
2014/12/11 18:55:49.944 Received client request: Julien-PC|192.168.0.27|OpenLiveStream|5509787|0|8|D8/8
Not work "xxx, 000MHz"
2014/12/11 18:55:49.944 OpenLiveStream> -----------------start------------------------
2014/12/11 18:55:49.944 OpenLiveStream> client: Julien-PC requesting live stream
2014/12/11 18:55:50.026 LiveRemuxStream> live-tv started
2014/12/11 18:55:50.028 SetChannel> Channel: 8 : D8 - 54129B = { (8 : D8 - 541292) + [ 8 : D8 - 5412D3, 8 : D8 - 541309, 8 : D8 - 54133F, 8 : D8 - 541375] }
2014/12/11 18:55:50.030 SetChannel> Tuners available for this channel: 6
2014/12/11 18:55:50.030 SetChannel> Tuner DecoyMethod: OnDemand
2014/12/11 18:55:50.030 SetChannel> ---
2014/12/11 18:55:50.030 SetChannel> Attempt: 0, Tuner: Hauppauge WinTV-HVR 713X BDA DVBT Tuner / 93defc4b-becc-4f25-a088-f14c1ec34274
2014/12/11 18:55:50.030 SetChannel> > Encrypted: False
2014/12/11 18:55:50.036 SetChannel> > RecorderInfo found: True
2014/12/11 18:55:50.037 SetChannel> > Recorder Content Protection: PROT_COPY_FREE
2014/12/11 18:55:50.038 SetChannel> > Status: Available, client:
2014/12/11 18:55:50.038 SetChannel> *** requested number of available tuners found, stopping search ***
2014/12/11 18:55:50.038 SetChannel> ---
2014/12/11 18:55:50.038 SetChannel> available tuners found: 1 [decoys:0], requested: 1, searched: 1
2014/12/11 18:55:50.038 SetChannel> Tuner: Hauppauge WinTV-HVR 713X BDA DVBT Tuner will be used for the live stream
2014/12/11 18:55:50.042 SetChannel> Recorder acquired: True
2014/12/11 18:55:50.047 SetChannel> TuneRequest set
2014/12/11 18:55:50.082 LiveRemuxStream> wtv recording started in 0,06 sec
2014/12/11 18:55:50.082 LiveRemuxStream> stream output file: LiveTV_Julien-PC_DVB-T_8_2014_12_11_18_55_50.ts
2014/12/11 18:55:50.083 LiveRemuxStream> started remux thread: 'D8-8:5509787'
2014/12/11 18:55:50.279 Remux::FindDescriptors> Scanning wtv for streams...
2014/12/11 18:55:55.769 Parse> Guid: 0 took 5,49 sec, it was attempted 2638 times
2014/12/11 18:55:55.773 Parse> Next 4 Guids: 0,00 sec, 0,00 sec, 0,00 sec, 0,00 sec,
2014/12/11 18:56:10.361 WaitForTsFile> timeout reached, throwing exception
2014/12/11 18:56:10.361 LiveRemuxStream> process start error: Stream file 'ts' does not exist (likely no data was found to remux), timeout: 20 000 ms reached. calling Close()
2014/12/11 18:56:10.361 Remux::Stop> caller is requesting to stop remux thread before descriptors are found
2014/12/11 18:56:10.361 Remux::Stop> stop remux requested
2014/12/11 18:56:10.361 WtvToPesDemuxer::Parse> Guid header detects stream end
2014/12/11 18:56:10.362 Parse> Descriptor pass done, using 37 guids in 14,59 sec
2014/12/11 18:56:10.362 Parse> Total Descriptor parse time: 20,08 sec
2014/12/11 18:56:10.362 Pass 'Descriptor':
2014/12/11 18:56:10.362 > WtvToPesDemuxer::Parse> total guid headers processed: 37
2014/12/11 18:56:10.362 > WtvToPesDemuxer::Parse> total data packets processed: 0
2014/12/11 18:56:10.362 Remux::FindDescriptors> no streams descriptors were found.
2014/12/11 18:56:10.362 Remux::FindDescriptors> error: no audio or video stream found - aborting remux
2014/12/11 18:56:10.362 Remux> error: System.Exception: FindDescriptors failed
à Remuxer.Remux.Start(String clientName, String outFullFileName)
2014/12/11 18:56:10.362 Remuxer::Start> warning: no MuxFilter output in list during remux shutdown.
2014/12/11 18:56:10.363 Remux> requesting D:\TV enregistrée\TempSWMC\LiveTV_Julien-PC_DVB-T_8_2014_12_11_18_55_50.wtv be saved from deletion
2014/12/11 18:56:10.363 Remux> ENDED, >>>>>>>>>> Run Time: 0,00 min <<<<<<<<<<
2014/12/11 18:56:10.381 LiveRemuxStream::Close> remux stopped successfully
2014/12/11 18:56:10.381 LiveRemuxStream::Close> warning: error: no ts file is streaming at remux shutdown
2014/12/11 18:56:10.382 RecordToWTV::Close> isPassive is False => COM recorder will be stopped
2014/12/11 18:56:10.647 LiveRemuxStream::Close> wtv closed successfully
2014/12/11 18:56:10.698 LiveRemuxStream::Close> wtv file size: 524 288 (0x80000)
2014/12/11 18:56:10.698 LiveRemuxStream::Close> wtv file NOT saved for debug, contains no data
2014/12/11 18:56:10.698 LiveRemuxStream::Close> closed in 0,34 sec
2014/12/11 18:56:10.698 OpenLiveStream> error: Stream file 'ts' does not exist (likely no data was found to remux), timeout: 20 000 ms reached.
2014/12/11 18:56:10.699 Finished request OpenLiveStream in 20,76s
thanks you for your software and work
hi,
If I understand correctly, you need to include some frequencies, even though they don't work, in order to get guide data to show up for some channels. Then the problem is serverwmc tries to tune to these bad frequencies for live-tv. This is because we changed newer versions of serverwmc to use lower priority frequencies in order to protect live tv streams from a recording starting on the same channel.
You can turn this off by going to the 'debug' tab in serverwmc and choose 'edit the settings file'. In this file, search for Decoy_FixedDecoysPerLiveStream and change it to this:
<Decoy_FixedDecoysPerLiveStream>0</Decoy_FixedDecoysPerLiveStream>
this will force serverwmc to use only high priority frequencies like wmc does. After making the change, save the file and restart serverwmc.
Does that solve the problem?
Thanks for the information about what 'mcGlidHost.exe' does. That was new to me.
Thank you for the quick response. Having disable "Decoy_FixedDecoysPerLiveStream" has not worked for me.
I think serverwmc does not like channels with errors and fails to provide a ts file.
Anyway I just had too much problem leaving mcGlidHost.exe manage the frequences.WMC unable to remain stable with frequencies other than "xxx 167MHz" .I am forced to disable mcGlidHost.exe otherwise it will I put unstable frequencies. The best thing for me would be to force the frequency "xxx, 167MHz" and let mcGlidHost.exe take epg without changing frequencies. But mxf files are too scared me.
Thank you again to insane software.
