Full Version: HOW-TO: Creating an IMDB top 250 view
Here is a quick guide to creating a Movie view of the IMDB top 250 films using Aeon 5
Requirements
XBMC Gotham
Aeon Nox 5 Skin
service.library.data.provider
Step 1
Copy all your files IMDB best movies into a separate folder like this and add as a video source
Step 2
Setup a movie playlist by going to Videos >> Playlists >> New Smart Playlist
Set the type to movies, the name to "Top 250", and a condition that filters the playlist where the path contains the folder name you put your top 250 movies in.
Make sure the order by is descending rating so we can show the best movies at the top of the list.
Step 3
In the Aeon skin settings go to System >> Appearance >> Skin >> Skin settings >>Setup the main Nox menu >> Movies >> Manage Sub menu
Create a new sub menu by hitting the add button, make sure the new sub menu is selected on the left and change the label to "Top 250".
Now hit the "type" button until it shows all the playlists, then select the "Top 250" playlist you created earlier.
Step 4
Now simply go to the Movies main menu and hit the down arrow to show the sub menus.
Select the "Top 250" sub menu and you should see your movies listed in imdb rating order.
If they are not sorted properly you can do it manually using the left hand menu,
Final Result
This should be what you see.
As there is no slim list view in Aeon, I find the best alternative is the tri panel view
NOTE: If you don't want your main movie view to include these movies then you can make another smart playlist for your main movie collection in the same way using path filters. Then just link that to the "Movie" button in the Aeon menu settings.
For anyone who wants to mix up their movies all together you can use the universal scraper and a special smart playlist
(2014-06-15, 21:39)Warner306 Wrote: [ -> ]There's an easier way to create an IMDb Top 250 playlist than putting files into separate folders by using the built-in playlist tools. They are already capable of finding the Top 250 tag if you scrape your collection with the Universal Movie Scraper:
On an unrelated note, an Oscars Best Picture playlist is a similar type of playlist that can be created by adding a suffix to the file name of all Oscar winners and then setting the playlist to filter by files that end in ".oscars". That is another of my favourites.
(2014-06-15, 22:23)zag Wrote: [ -> ]For anyone who wants to mix up their movies all together you can use the universal scraper and a special smart playlist
I added .oscar but it is not working
Please show a sample
This would be a good idea for a request for a Kodi feature, or Kodi add-on, to be able to sort movies by Oscar winners / nominations, or to show only IMDB top 250 winners.
(2016-02-13, 23:29)madmax2 Wrote: [ -> ]
You would have to post a picture of your playlist.
(2016-02-14, 14:59)Sjors125 Wrote: [ -> ]This would be a good idea for a request for a Kodi feature, or Kodi add-on, to be able to sort movies by Oscar winners / nominations, or to show only IMDB top 250 winners.
Yes!! Or to be able to stack filters and say, Oscar winners in X genre...
(2016-02-13, 23:29)madmax2 Wrote: [ -> ]I added .oscar but it is not working
I made a tag generator that looks for local matches. You can point it at any IMDB list and give your movies any tag - might help here.
