2014-06-20, 00:13
2014-06-20, 00:21
Yes you can! Good luck
2014-07-20, 11:30
This is a nice skin i use it in my htpc but on tablet the play contorl doesnt work great (cant drag the time line to the period i need). If you can give some detail on how to replace the playback contorl from confluence will be nice.
thanks
thanks
2014-07-22, 02:26
(2014-07-20, 11:30)kwanying Wrote: [ -> ]This is a nice skin i use it in my htpc but on tablet the play contorl doesnt work great (cant drag the time line to the period i need). If you can give some detail on how to replace the playback contorl from confluence will be nice.
thanks
It's not optimized for Touchscreen devices (yet)
2014-09-30, 18:00
Yep I'd like this very much too.. I dont want to 'benny hill' styly fast forward through all my media
2014-09-30, 18:31
It just needs a time bar and this skins purrfect.
2014-10-12, 15:54
Also a new user of refocus, it's great, especially the sounds.
But the playback control is indeed a let down, needs a progress bar and the highlighted button when it first opens should be "pause".
2015-06-26, 02:50
So I guess nothing is going to happen in here huh? I too love this skin, and think different controls would put this skin over the edge of amazing.
2015-07-04, 12:31
I found this thread looking for the same feature asked earlier on, and found that there had not been any answers on getting a progress slider added to the video menu. So I modded my own copy to include a progress slider. What are the forum requirements for submitting it so others can use it as well?
thanks!
thanks!
