Full Version: Toonjet
Pages: 1 2
plugin.video.toonjet
What it is: http://www.toonjet.com
Welcome to ToonJet, your first-class ticket to watch free online cartoons! ToonJet has now taken flight, and there are many, many cartoons to download and watch
Features:
  • Links to Youtube Channel for listing all videos. http://www.youtube.com/ToonJetOfficial
  • Support to set Viwemodes for current skin or any custom viewmode under settings. Supports all skins as of 2015-02-20.
  • Add-To / View Playlist via Context Menu.
  • All HTTP Resources are cached localy for speed improvements, allowing for HTTP 304 not modified support.
  • Any HTTP Resource can be forced refreshed via Context Menu.
  • Also list by Highest Rated and and Most Viewed.
Tested with Helix on:
Windows, Linux
Download:
This add-on can be found in the official kodi.tv add-on repository.
This add-on can also be downloaded from my Git Repo.
Version 2.0.0 2015-02-20
- Fix forum url in addon.xml
- Removed download support
- Changed to use the YouTube V3 API
- Changed to auto select content type
- Changed to auto select sort methods
- Changed settings.xml to use new methods for setting view mode
- Switch to using with statement
- Some small method renames
Source Code: https://github.com/willforde/plugin.video.toonjet
Note If you get error "Dependencies not met". You may need to install the latest script.module.xbmcutil addon.
Great addon.
tnx
Add-on has been updated to add a small few features and some bug fixes. And some speed improvements as well.
P.S. I am always looking for ways to improve this add-on if anyone has any suggestions.
thumbnails have a really low resolution, no way to increase quality?
just updated manually from your repo and the addon give me: url errore, decompression error.
here part of my log with the error:
http://pastebin.com/raw.php?i=ZdrREszs
any idea?
Peppe
Thank you so much for that debug log. I found the problem. Big oops on my part. I had to change the X-Cache to X-Local-Cache flag to fix a problem when using a proxy caching server.
The problem is that anyone that still has a valid cache will have that error.
It can be quickly fixed by deleting the plugin.video.toonjet userdata folder. /Kodi/userdata/addon_data.
For you it should be be C:\Users\Peppe\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.toonjet
I will hopefully have a updated script.module.xbmcutil addon for later today that will fix this bug.
P.S. I have added some local high res images to replace the low quality ones from the site. For now the update can been got from here. v2.0.1
https://github.com/willforde/xbmc.repo.f...eo.toonjet
same problem.....
http://pastebin.com/raw.php?i=051rWqWR
thanks for hi res images.
Peppe
I have update the back-end scripts that I believe was causing the problem. Below is the link to the git hub page where you can download the update. v3.0.1
https://github.com/willforde/xbmc.repo.f...e.xbmcutil
Please let me know how it goes as this bug effects all my add-ons. Thanks.
ok mate, it is working now.
tnx
Peppe
Thanks for the testing. I have just submitted the update to the official repository.
I'm getting this error:
<urlopen error [Errno 111] Connection refused>
Toonjet.com is also down it would appear
I'm getting this error as well. I'm guessing this add-on is dead?
Site is gone down again. Should be back soon, Hopefully.
Unfortunately this site goes down a lot.
I will double check the addon when the site comes back to make sure every thing is working as it should.
Thanks wally for the info
Is this legal? How?
Pages: 1 2
