Full Version: No posters for "My TV Shows --> TV Shows in progress"
Hello together,
I`ve started using Bello and I'm a great fan of the clear design and functionality. When clicking through the possibilities of Bello, I've find out, that under the "My TV Shows" menu point I can click down further with the cursor and then I can directly switch to "Recently added TV Shows", "TV Shows in progress" or "Random TV Shows". Where I'm now a little bit struggling is, that on the one hand side for "Recently added TV Shows" I can see the posters - as expected
but for "TV Shows in progress" or "Random TV Shows" I can't see the posters:
But when I select "TV Shows in Progress" I have some:
Shouldn't there also be the posters of the appropriate shows visible?
Did you solve this ?
By the way, MOUSE USAGE IS NOT SUPPORTED.
Cheers
Nessus
Anyone able to resolve this?
I'm having the same issue. "Recently added" and "Random" are both showing up, but "TV shows in progress" is blank (as above post) until I click on it to see the full list.
This feature is essential for me and will be a deciding factor on whether I stick with this skin (which is otherwise excellent).
It's working fine here...
Skin version ?
Kodi version ?
Debug log ?
Keep in mind that if you use any mod version of the skin i can't help you.
Cheers
Nessus
Not near my computer so cant post debug log atm.
It is doing this for me in both Bello and Bello Nero, obviously we can try to resolve the former.
Skin - 2.0.7
Kodi/XBMC - 13.2 gotham
I have the same issue.
