2014-08-02, 21:40
I have recently been getting the error Script failed! Skin Widgets when I open XBMC program. I've tried uninstalling the Add-On and reinstalling, but I still get the error.
This started about 2 weeks ago, it used to work fine before.
I am using a SQL database when I get the error. If I use a local database I do not get the error and it works just fine.
Here is the Debug Log: http://xbmclogs.com/show.php?id=259197
Info:
XBMC 13.1
MQ5 skin
Windows 8.1
Thanks in advance.
11:57:40 T:5660 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
898. - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
899. Error Type: <type 'exceptions.UnboundLocalError'>
900. Error Contents: local variable 'item2' referenced before assignment
901. Traceback (most recent call last):
902. File "C:\Users\Nik\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py", line 796, in <module>
903. Main()
904. File "C:\Users\Nik\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py", line 68, in __init__
905. self._fetch_info_recommended()
906. File "C:\Users\Nik\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py", line 127, in _fetch_info_recommended
907. self._fetch_tvshows_recommended('RecommendedEpisode')
908. File "C:\Users\Nik\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py", line 269, in _fetch_tvshows_recommended
909. if (item2['resume']['position'] and item2['resume']['total']) > 0:
910. UnboundLocalError: local variable 'item2' referenced before assignment
911. -->End of Python script error report<--
Info:
XBMC 13.1
MQ5 skin
Windows 8.1
Thanks in advance.
