Full Version: Buffering problem when +4Mb/sec
Hi there, the plugin is working great on my rooted Amazon fireTV, thanks for that, great work ! I'm using Gotham 13.2. I've try with Frodo, Gotham 13 and 13.1 and SPMC.
I'm using Hauppauge Colossus to record from a STB and my video bitrate is set to Variable from 1 to 14 Mb/sec.
On the FireTV i'm wired and I use Tsreader 'cause FFmpeg has video glitch but runs ok.
Here's my problem, XBMC will start to 'eat' buffer if the Mb/sec exceed 4Mb/sec. It's a problem ONLY on the TV side. Even if I watch from a recorded program, same thing. But if I watch recorded program from SMB sharing folder, everything is great, I got 100% in the buffer 'till the end.
I'm able to test any plugin build 'cause my FireTV is rooted,
Here's my advancedsettings.xml
<advancedsettings>
  <network>
    <buffermode>1</buffermode>
    <cachemembuffersize>20971520</cachemembuffersize>
    <readbufferfactor>2</readbufferfactor>
  </network>
  <video>
    <stagefright>
      <!--  -1 is default, 0 is never used this codec, 1 is always use this codec, bypassing blacklist -->
      <useavccodec>1</useavccodec>
      <usevc1codec>1</usevc1codec>
      <usevpxcodec>1</usevpxcodec>
      <usemp4codec>0</usemp4codec>
      <usempeg2codec>0</usempeg2codec>
      <useswrenderer>false</useswrenderer>
    </stagefright>
  </video>
</advancedsettings>
Thanks a lot margro for this great plugin.
(2014-08-15, 14:54)kalouka Wrote: [ -> ]Hi there, the plugin is working great on my rooted Amazon fireTV, thanks for that, great work ! I'm using Gotham 13.2. I've try with Frodo, Gotham 13 and 13.1 and SMPC.
<advancedsettings>
  <network>
  </network>
  <video>
    <stagefright>
    </stagefright>
  </video>
</advancedsettings>
Have you found a solution yet?
I have same issue, tried all available configs. I read, that adv.conf. does not work for live tv...same impression i got.
BR
(2014-10-01, 18:32)4irm Wrote: [ -> ]Have you found a solution yet?
BR
Nope, If a developper manifest himself, maybe we'll have a chance to nail the problem down.
I'm using the SPMC version 13.3.3 (2014/10/26) since yesterday, and I don't have this buffering problem anymore !!!!
I don't know if it's the Mediaportal PVR plugin version or SPMC that fix the bug but now its fine !
