Full Version: 14.0-ALPHA3 PVR VU+ Connection Problems
Hi Folks.
Im using the newest version of Kodi form an nightly build on an ubuntu 12.04.05 LTS to view livetv and records from my dreambox 800se.
Here is the log for all information you may need.
20:31:45 T:140144367343488  NOTICE: Starting Kodi (14.0-ALPHA3 Git:fbf1515). Platform: Linux x86 64-bit
20:31:45 T:140144367343488  NOTICE: Using Release Kodi x64 build
20:31:45 T:140144367343488  NOTICE: Kodi compiled Aug 18 2014 by GCC 4.6.3 for Linux x86 64-bit version 3.2.60 (197180)
20:31:45 T:140144367343488  NOTICE: Running on Ubuntu precise (12.04.5 LTS), kernel: Linux x86 64-bit version 3.2.0-65-generic
20:31:45 T:140144367343488  NOTICE: FFmpeg statically linked, version: 2.3.2-xbmc-2.3.2-Helix-alpha3
20:31:45 T:140144367343488  NOTICE: Host CPU: AMD Athlon(tm) II X2 240e Processor, 2 cores available
20:31:45 T:140144367343488  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:31:45 T:140144367343488  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
20:31:45 T:140144367343488  NOTICE: special://masterprofile/ is mapped to: /home/pumpa/.xbmc/userdata
20:31:45 T:140144367343488  NOTICE: special://home/ is mapped to: /home/pumpa/.xbmc
20:31:45 T:140144367343488  NOTICE: special://temp/ is mapped to: /home/pumpa/.xbmc/temp
20:31:45 T:140144367343488  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
Unfortunally the xbmc-pvr-vuplus (installed from utbuntu repo) doesnt work. I think since the last update to kodi.
ii  xbmc-pvr-vuplus                            1.9.14-13precise                           XBMC PVR Addon Vuplus - PVR API:1.9.1
I think this is the intresting part of the logfile.
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - VU+ Addon Configuration options
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - Hostname: '192.168.2.101'
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - WebPort: '80'
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - StreamPort: '8001'
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: Open Use HTTPS: 'false'
20:36:42 T:140144367343488  NOTICE: PVRManager - stopping
20:36:42 T:140142851331840  NOTICE: Thread FileCache start, auto delete: false
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: GetDeviceInfo - DeviceInfo
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: GetDeviceInfo - E2EnigmaVersion: ramiMAHER-
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: GetDeviceInfo - E2ImageVersion: Newnigma2 v3.3.2 2012-03-28
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: GetDeviceInfo - E2WebIfVersion: 1.6.8
20:36:42 T:140142702491392  NOTICE: AddOnLog: VU+ / Enigma2 Client: GetDeviceInfo - E2DeviceName: dm800se
20:36:43 T:140142702491392  NOTICE: Previous line repeats 2 times.
20:36:43 T:140142702491392   ERROR: ADDON: Dll VU+ / Enigma2 Client - Client returned bad status (1) from Create and is not usable
20:36:43 T:140142702491392 WARNING: UpdateAndInitialiseClients - failed to create add-on VU+ / Enigma2 Client, status = 1
20:36:43 T:140143394465536  NOTICE: Thread AddonStatus pvr.vuplus start, auto delete: true
The only thing i understand is, that plugin have problems to start. Do you know why?
At least i could say that i dont have done any configurations on my dreambox. So it is possible to visit the dreambox via a normal browser, download and stream movies (with vlc) on pc and android handy.
I realy hope you can help me to solve this problem.
Best regards
flynk
