I am still new to xbmc, have a matricom mx2 box running SPMC and wanted to see is I can use my synology 112 to record TV shows. I emailed synology support to see which DVD is compatible with my nas and this is what I got
" Thank you for contacting Synology Support.
Unfortunately the DVB-T standard isn't supported within north america, the north american standard is ATSC
http://en.wikipedia.org/wiki/ATSC_tuner so you will not be able to record."
So does this mean I can't have a pvr backend with my xbmc to record shows?
Thanks, Vineet
Sure you can have a backend but this won't be the Synology.
Thanks, can you name a few if it's ok ?
You find the list of PVR bachends on top of this page:
http://forum.xbmc.org/forumdisplay.php?fid=167
TVH, VDR (VNSI), MythTV are popular on Linux systems, choose one the others if you prefer Windows. Then you need a tv card which is capable of ATSC and supports the OS.
Many NAS products are running Linux so users can use them as a PVR backend too. Maybe this is true for Synology as well but they simply never have tested ATSC and don't officially support it.
Visit this page for a list of Linux ready ATSC Devices:
http://www.linuxtv.org/wiki/index.php/ATSC_Devices
Take this as an example:
http://www.hauppauge.com/site/products/data_hvr850.html, approx. $60, plug it in some Linux Box, install TVH, VDR + VNSI, or MythTV and you have your PVR backend.
I use my synology with dvblink package. Antenna is attached to the hdhomerun pro
(2014-09-03, 13:16)jayleekay Wrote: [ -> ]I use my synology with dvblink package. Antenna is attached to the hdhomerun pro
U.S.?
Only backend I've had success with in the U.S. is
ServerWMC.
Update: found this. Looks like Synology plug-in will work, but you don't get any guide data for U.S.
I have used serverWMC very simple and works well, and Argus TV which is significantly harder to set up but has much more control of scheduling.
thank you guys. I will try ServerWMC.
EDIT: looks like ServerWMC is windows only
jayleekay- do you use your synology with DVB in USA? also what model is your synology? Mine is 112 and I want to ensure DVB would work on it.
There is no dvb in north America.
I have a 213j I believe. It has the armada370 and use atsc . mc2xml to get my EPG and it works great.
