Full Version: Update script for Kodi nightlies
This PHP script automatically detects the newest XBMC / Kodi nightly for Mac, downloads it and replaces it with the old version.
Warning: you shouldn't use a Nightly if you're not 100% sure that you really want that. It may brick your XBMC / Kodi installation!
How To:
Open the Terminal and run the following command:
curl https://gist.githubusercontent.com/yanniks/8e228698e9d381602d32/raw | bash
After that, you can update Kodi while running the kodiupdate command on the Mac.
How do I remove this script?
If you want to remove this script, just delete this file: /usr/bin/kodiupdate
Update 11/26/2014: Small Kodi changes
Just found this. Still works well
